Updated on 2022-05-17 GMT+08:00
OBS Resources
A resource is an object that exists within a service. OBS resources include buckets and objects. You can select these resources by specifying their paths.
Table 1 OBS resources and their paths
Resource Type
Resource Name
Path
bucket
bucket
[Format]
obs:*:*:bucket:bucket name
[Notes]
For bucket resources, IAM automatically generates the prefix of the resource path: obs:*:*:bucket:
For the path of a specific bucket, add the bucket name to the end. You can also use an asterisk * to indicate any bucket. Example:
obs:*:*:bucket:*
object
object
[Format]
obs:*:*:object:bucket name/object name
[Notes]
For object resources, IAM automatically generates the prefix of the resource path: obs:*:*:object:
For the path of a specific object, add the bucket name/object name to the end. You can also use an asterisk * to any object in a bucket. Example:
obs:*:*:object:my-bucket/my-object/*: indicates any object in the my-object directory of the my-bucket bucket.
