Updated on 2022-05-17 GMT+08:00
Using OBS
You can use the following tools to access and manage OBS resources:
Table 1 OBS resource management tools
Tool
OBS Console
OBS Console is a web-based GUI. You can perform operations on OBS Console easily.
OBS Browser+
OBS Browser+ is an OBS client running on Windows operating systems. You can use OBS Browser+ to manage the storage of objects on your PC.
obsutil
obsutil is a command line tool for accessing OBS. You can use this tool to perform common configurations in OBS. If you are familiar with command line interface (CLI), obsutil is recommended as an optimal tool for batch processing and automated tasks.
API
With the API, you can easily access OBS from web applications. By making API calls, you can upload and download data anytime, anywhere, or through any Internet device.
