Updated on 2026-11-02 GMT+08:00
Parallel File System Features
Compatibility Between OBS Bucket APIs and Parallel File Systems
You can call some OBS bucket APIs to use parallel file systems. There may be additional requirements when you call these APIs.
For details about the OBS bucket APIs, see Object Storage Service API Reference.
Permissions Configuration
The use cases and main functions of object access control also work on files in parallel file systems. For more information, see Permissions Configuration Guide.
Lifecycle Management
The use cases and main functions of object lifecycle management also work on files in parallel file systems. For more information, see Creating a Lifecycle Rule.
To manage the lifecycle using SDKs, see SDK Overview.
