Data Retrieval
Reading an object in the Warm or Cold storage class will incur data retrieval fees based on the object size. You are billed for data retrieval regardless of whether you read the objects over an intranet or internet connection. If you use an internet connection, you will also be billed for the outbound internet traffic generated.
Introduction
Category |
Billing Item |
Description |
Billing Mode |
Data retrieval |
Data read traffic |
You are billed for data retrieval regardless of whether you read the objects over an intranet or internet connection. If you use an internet connection, you will also be billed for the outbound internet traffic generated. After a Cold object is restored, an object copy is generated and stored in the Standard storage class. During the copy retention period, you will be billed for the storage space occupied by both the object and its copy. The object copy will be automatically deleted upon its expiration. The storage fee for the object copy in the entire validity period will be charged at a time when the object is restored. Retrieving Warm objects does not generated Standard object copies, and no additional fees are generated. |
Pay-per-use |
