Help Center/
      Object Storage Service/
        User Guide (ME-Abu Dhabi Region)/
        OBS Console Operation Guide/
        Versioning/
      Configuring Versioning
        Updated on 2022-05-17 GMT+08:00
- In the bucket list, click the bucket to be operated. The Overview page of the bucket is displayed.
 - Move the cursor over Disabled or Enabled next to Versioning in the Basic Information area. The Edit button is displayed next to the versioning status. Click Edit. The dialog box for editing the versioning status is displayed.
 - Select Enable.
 - Click OK to enable versioning for objects in the bucket.
 - Click an object to go to the object details page. On the Versions tab, view all versions of the object.
Follow-up Procedure
After versioning is enabled, on the object details page that is displayed, click Versions, and then you can delete and download versions of the object.
 - In the navigation pane, click Objects.
 - In the object list, click the target object. The system displays the object information.
 - On the Versions tab, view all versions of the object.
 - You can perform the following operations on object versions:
- You can download a desired version of the object by clicking Download on the right of the version.
       If the desired version is in the Cold storage class, it has to be restored before downloading.
 - You can delete a version of the object by clicking Delete on the right of the version. If you delete the latest version, the most recent version becomes the latest version.
   Parent topic: Versioning
