Resizing Images
You can use the GUI or code mode on OBS Console or make an API call to resize images. Images can be resized based on a specific rule or a fixed width, height, or percentage.
- A long side refers to the side with a larger ratio of its original size to its target size, and a short side refers to the side with a smaller ratio. Assume that the original size of an image is 400 × 200 pixels and it is resized to 100 × 100 pixels. The ratio of 400 pixels to 100 pixels is 4 and that of 200 pixels to 100 pixels is 2, so the long side is 400 pixels and the short side is 200 pixels.
- For a target image after resizing, its long side cannot exceed 9,999 pixels, and the product of its width and height cannot exceed 24,999,999 pixels.
- If you only specify the height or width for resizing, the target image keeps the same aspect ratio and format as the original image.
- By default, resizing is not allowed to scale up an image. If you want an image to become larger after resizing, you need to set limit to 0 to obtain the enlarged image, or the original image will be returned. To do this, use the following format:
Table 1 describes the parameters.
This operation is represented by resize.
Parameter |
Value Description |
Code Example |
m |
Type of resizing. The value can be lfit (the default value), mfit, fill, pad, or fixed.
image/resize,m_lfit,h_100,w_100 |
p |
Percentage of the aspect ratio, in the range of 1 to 1000. If the value is:
image/resize,p_50 |
h |
Height of the target image, in the range of 1 to 9999. The product of the target image's width and height cannot exceed 24,999,999. |
image/resize,m_lfit,h_100 |
w |
Width of the target image, in the range of 1 to 9999. The product of the target image's width and height cannot exceed 24,999,999. |
image/resize,m_fixed,h_100,w_100 |
l |
The long side of the target image, in the range of 1 to 4096. The product of the target image's width and height cannot exceed 24,999,999. The long side has a specified value, and the short side is scaled based on the ratio. |
image/resize,l_100 |
s |
The short side of the target image, in the range of 1 to 4096. The product of the target image's width and height cannot exceed 24,999,999. The short side has a specified value, and the long side is scaled based on the ratio. |
image/resize,s_100 |
color |
Color for filling the blank area after resizing. This parameter can be used when you set m to pad. The value is a hexadecimal code, from 000000 to FFFFFF (default value, representing white). |
image/resize,m_pad,h_100,w_100,color_FF0000 |
limit |
Whether to limit the size of the target image when the target image is larger than the original one. The value can be 0 or 1 (default value).
image/resize,p_150,limit_0 |
If a resized image is aliased, you can add /marker,u_plus to the end of the image processing URL for optimization.
For example, the image processing URL is as follows:
After the parameter is added, the link is as follows:
Examples
- Set h to 100 and m to lfit (the default value) to process the width proportionally.
- Lock the aspect ratio and specify the short side to resize the image into 100 × 100 pixels.
https://hw-image-demo.obs.ap-southeast-1.myhuaweicloud.com/example.jpg?x-image-process=image/resize,m_lfit,h_100,w_100
- Set the long side size to 100 and scale the short side based on the ratio.
- Fix the width and height, center and crop the image, resize the image into 100 × 100 pixels.
https://hw-image-demo.obs.ap-southeast-1.myhuaweicloud.com/example.jpg?x-image-process=image/resize,m_fill,h_100,w_100
- Fix both the width and height to 100.
- Fix the width and height. Resize the image into 100 × 100 pixels by specifying the short side and fill the blank area with white.
https://hw-image-demo.obs.ap-southeast-1.myhuaweicloud.com/example.jpg?x-image-process=image/resize,m_pad,h_100,w_100
- Fix the width and height. Resize the image into 100 × 100 pixels by specifying the short side and fill the blank area with red.
https://hw-image-demo.obs.ap-southeast-1.myhuaweicloud.com/example.jpg?x-image-process=image/resize,m_pad,h_100,w_100,color_FF0000
- Scale up the image to 150% of its original size and set limit to 0 to obtain the enlarged image.
- Set p to 30 to scale down the image to 30% of its original size.
- Set an image's aspect ratio to 3:2.
https://hw-image-demo.obs.ap-southeast-1.myhuaweicloud.com/example.jpg?x-image-process=image/resize,m_ratio,w_3,h_2
Resizing an Image by Editing Code on OBS Console
- On the homepage of the management console, click Service List in the upper left corner and choose Storage > Object Storage Service.
- In the bucket list, click the bucket you want to go to the Objects page.
- Click Upload Object to open the Upload Object dialog box.
- Click add files marked by red box in Figure 1 to open the local file browser.
- Select the image that you want to upload and click Open.
- Click Upload to upload the image. The uploaded image is displayed in the object list.
- In the navigation pane, choose Data Processing > Image Processing.
- Click Create to go to the style editing page.
- Set Style Name to style002 and choose Code for Edit Mode.
- In the code input box, type the following command for resizing.
Specify a rectangle whose width (indicated by w) and height (indicated by h) are both 100. Lock the aspect ratio, and obtain the smallest image in the extended area of the 100 × 100 rectangle.
image/resize,m_mfit,h_100,w_100
The style effect will be displayed on the right in real time. Figure 2 shows the final style effect.
- Click OK to save the style. The new style style002 will be displayed in the style list.
- In the navigation pane, choose Objects. Click mountain.jpg in the object list to go to the file details page.
- Click the Preview Image tab to preview the effect of the image with style style002 applied.
Figure 3 Preview Image
- In the image style card, click Copy Link. When Copied successfully. is prompted, you will have the address for accessing the image with the style applied.
