You are the bucket owner or you have the permission to write the bucket ACL.
Ways to Configure a Bucket ACL
You can configure a bucket ACL using OBS Console, APIs, SDKs, obsutil, or OBS Browser+.
Using OBS Console
- In the navigation pane of OBS Console, choose Buckets.
- In the bucket list, click the desired bucket. The Objects page is displayed.
- In the navigation pane, choose Permissions > Bucket ACL.
- On the Bucket ACL page, choose Private, Public Read, or Public Read/Write to grant anonymous users access to the bucket ACL.
- After you change Public Read or Public Read/Write to Private, only the bucket owner or object owner has the access.
- After you change Private to Public Read, anyone can read objects in the bucket. No identity authentication is required.
- After you change Private to Public Read/Write, anyone can read, write, and delete objects in the bucket. No identity authentication is required.
Figure 1 Changing a public access permission
- In the Operation column, click Edit to grant the owner, anonymous user, or log delivery user required ACL permissions for the bucket.
- In the middle of the page, click Export to get the bucket ACL configuration. The file includes the user type, account, bucket access, and ACL access.
- In the middle of the page, click Add to apply specific ACL permissions to an account.
Click OK.
Figure 2 Granting permissions
Table 1 Bucket access permissions | Permission | Description |
| Read | Grants the permission to obtain the list of objects in the bucket and the metadata of the bucket. |
| Write | Grants the permission to upload objects to the bucket and to delete and overwrite existing objects in the bucket. |
Table 2 Object access permissions | Permission | Description |
| Object read | Grants the permission to obtain the content and metadata of objects in the bucket. The objects inherit the read permission configured for the bucket. |
Table 3 ACL access permissions | Permission | Description |
| Read | Grants the permission to read the bucket ACL. |
| Write | Grants the permission to update the bucket ACL. |
Using the GUI Tool - OBS Browser+
- Log in to OBS Browser+.
- Select the bucket you want and click Bucket ACLs.
- Configure the bucket ACL as needed and click OK, as shown in Figure 3.
Figure 3 Configuring an ACL
If no ACL permissions are configured for a new bucket, OBS Browser+ automatically disables the access to the bucket and its objects by any other users except the bucket owner.
Using the CLI Tool - obsutil
Command Line Structure
- Windows
obsutil chattri obs://bucket [-sc=xxx] [-acl=xxx] [-aclXml=xxx] [-config=xxx] [-e=xxx] [-i=xxx] [-k=xxx] [-t=xxx]
- macOS or Linux
./obsutil chattri obs://bucket [-sc=xxx] [-acl=xxx] [-aclXml=xxx] [-config=xxx] [-e=xxx] [-i=xxx] [-k=xxx] [-t=xxx]
Examples
Parameter Description
| Parameter | Optional or Mandatory | Description |
| bucket | Mandatory | The bucket name |
| sc | Optional (additional parameter) | The default storage class of the bucket. The value can be: - standard: Standard storage class. It features low access latency and high throughput, and is suitable for storing frequently accessed data (multiple accesses per month) or data that is smaller than 1 MB.
- warm: Infrequent Access storage class. It is ideal for storing infrequently accessed data (less than 12 times a year), but when needed, the access has to be fast.
- cold: Archive storage class. It provides secure, durable, and inexpensive storage for rarely-accessed data (once a year).
- deep-archive: Deep Archive storage class. It is ideal for storing data that is hardly ever accessed (once every few years). This storage class costs less than the Archive storage class, but takes longer (usually several hours) to restore data.
NOTE: If the multi-AZ mode is enabled for a bucket, the default storage class of the bucket cannot be set to cold. |
| acl | Optional (additional parameter) | The predefined access control policy of the bucket. The value can be: - private
- public-read
- public-read-write
NOTE: The preceding three values indicate private read and write, public read, and public read and write. |
| aclXml | Optional (additional parameter) | The bucket's access control policy, in XML format <AccessControlPolicy>
<Owner>
<ID>ownerid</ID>
</Owner>
<AccessControlList>
<Grant>
<Grantee>
<ID>userid</ID>
</Grantee>
<Permission>[WRITE|WRITE_ACP|READ|READ_ACP|FULL_CONTROL]</Permission>
</Grant>
<Grant>
<Grantee>
<Canned>Everyone</Canned>
</Grantee>
</Grant>
</AccessControlList>
</AccessControlPolicy> NOTE: - Owner: Optional. Specify the bucket owner's ID.
- In AccessControlList, the Grant field contains the authorized users. Grantee specifies the IDs of authorized users. Canned specifies the authorized user group (currently, only Everyone is supported).
- The following permissions can be granted: WRITE (write), WRITE_ACP (write ACL), READ (read), READ_ACP (read ACL), and FULL_CONTROL (full control).
NOTICE: Because angle brackets (<) and (>) are unavoidably included in the parameter value, you must use quotation marks to enclose them for escaping when running the command. Use single quotation marks for Linux or macOS and double quotation marks for Windows. |
| bucket-cname | Optional (additional parameter) | The user-defined domain name bound to the bucket NOTE: This parameter is only supported by obsutil 5.7.9 and later. |
| config | Optional (additional parameter) | The user-defined configuration file for executing the current command. For details about parameters that can be configured, see Configuration Parameters. |
| e | Optional (additional parameter) | The endpoint |
| i | Optional (additional parameter) | The user's AK |
| k | Optional (additional parameter) | The user's SK |
| t | Optional (additional parameter) | The user's security token |
Only one from sc, acl, or aclXml can be set for each command.
Follow-up Procedure
A registered user can access a bucket in either of the following ways:
- After an account is granted permissions through a bucket ACL, authorized users can use their own identity credentials (AK and SK) to access that bucket by adding the bucket to OBS Browser+.
- After certain permissions are granted to an anonymous user, the anonymous user can access the bucket without any authentication. The anonymous user can be either a registered user or a non-registered user.
A non-registered user can access a bucket in either of the following ways:
- Access the bucket's domain name in a browser to view the objects in the bucket.
- Configure the bucket's domain name in a third-party system to directly connect to the bucket.
