Replicating Bucket Policies
OBS allows you to replicate the existing bucket policies to a new bucket. When replicating policies, OBS automatically replaces the bucket name in the source bucket policies with the destination bucket name, for the policies to apply to the destination bucket.
- The policies replicated from a source bucket will not overwrite existing policies in the destination bucket.
- The source policies with the same name as those in the destination bucket will not be replicated.
- Both source and destination buckets must be of the 3.0 version.
- In the navigation pane of OBS Console, choose Object Storage.
- In the bucket list, click the bucket you want to operate to go to the Objects page.
- In the navigation pane, choose Permissions > Bucket Policies.
- Click Replicate.
- Select a replication source, which is the bucket whose policies you want to replicate.
After you select a replication source, all bucket policies with different name from those in the destination bucket are displayed. You can remove any that are not required.
Figure 1 Replicating bucket policies
- Click OK to replicate the bucket policies to the destination bucket.
