Deleting a File
Deleting unnecessary files saves space and costs. On OBS Console, you can delete files one by one or in a batch.
- In the bucket list, click the bucket to be operated. The Overview page of the bucket is displayed.
 - In the navigation pane on the left, click Objects.
 - Select the file you want to delete, and choose More > Delete on the right.
You can select multiple files and click Delete above the file list to batch delete the files.
 - Click Yes to confirm the deletion.
The object deletion task is displayed in the Task Management window.
