Updated on 2022-05-17 GMT+08:00
OBS Monitoring Metrics
Functions
This section defines the namespace, list, and dimensions of monitoring metrics reported by OBS to Cloud Eye. You can use the management console or APIs provided by Cloud Eye to search for monitoring metrics and alarms generated by OBS.
Namespace
SYS.OBS
Monitoring Metrics
Metric ID
Metric
Value Range
Monitored Entity
Monitoring Period (Original Metric)
download_bytes
Bytes Downloaded
Specifies the response bytes of all download requests made to all buckets in a region, including bytes in HTTP entity bodies.
Unit: byte
≥ 0 bytes
Bucket
5 min
upload_bytes
Bytes Uploaded
Specifies the bytes of all upload requests made to all buckets in a region, including bytes in HTTP entity bodies.
Unit: byte
≥ 0 bytes
Bucket
5 min
get_request_count
GET Requests
Specifies the number of GET, HEAD, or OPTIONS requests made to all buckets and objects in the buckets of a region.
Unit: count
≥ 0 counts
Bucket
5 min
put_request_count
PUT Requests
Specifies the number of PUT, POST, and DELETE requests made to all buckets and objects in the buckets of a region.
Unit: count
≥ 0 counts
Bucket
5 min
first_byte_latency
First Byte Download Delay
Specifies the average time from receiving a GET, HEAD, or OPTIONS request to the time that the system starts to respond in a measurement period.
Unit: millisecond
≥ 0 ms
Bucket
5 min
request_count_4xx
4xx Errors
Specifies the times that the server responds to requests whose error codes are 4xx.
Unit: count
≥ 0 counts
Bucket
5 min
request_count_5xx
5xx Errors
Specifies the times that the server responds to requests whose error codes are 5xx.
Unit: count
≥ 0 counts
Bucket
5 min
Dimensions
Table 1 Dimensions
Key
Value
bucket_name
Bucket dimension. The value is the bucket name.
