Block Public Access
Public access means that a requester can access a bucket and data in the bucket without specific permissions or identity authentication, risking data leakage, malicious access, and high external network traffic. To avoid these risks, OBS allows you to enable Block Public Access for a bucket to ensure data security. With Block Public Access, bucket owners can easily configure centralized controls to restrict public access to resources.
This feature is supported only in certain regions (for example, CN East-Qingdao and LA-Mexico City1). For the actual support status, refer to the console.
Checking Whether a Bucket Is Publicly Accessible
You need to determine whether a bucket is public based on its bucket policies and ACL. If a bucket policy or the ACL allows public access, you can enable Block Public Access to avoid exposure.
- If Principal in a bucket policy is set to * and the condition keys, operators, and values meet the requirements listed in the following table, the bucket policy allows public access.
Table 1 Conditions keys used for public access in bucket policies Condition Key
Operator
Value Description
PrincipalID
StringLike
The first segment of characters separated by a colon (:) contains a wildcard character.
PrincipalAccount
StringLike
There is a wildcard.
DomainId
PrincipalOrgID
PrincipalOrgManagementAccountID
SourceVpc
SourceVpce
SourceIP
IpAddress or NotIpAddress
The number of valid IPv4 addresses exceeds 2^{32-8}, or the number of valid IPv6 addresses exceeds 2^{128-32}.
PrincipalUrn
StringLike
The URN does not contain five segments or the third segment (Account) contains a wildcard character.
PrincipalOrgPath
StringLike
The first segment of characters separated by a slash (/) contains a wildcard character.
A wildcard character is an asterisk (*) or a question mark (?).
Example 1: Principal is set to *.1 2 3 4 5 6 7
{ "Principal": "*", "Resource": "*", "Action": "PutObject", "Effect": "Allow", "Condition": { "StringLike": {"SourceVpc": "vpc-*"}} }
Example 2: The value of SourceVpc contains a wildcard character.
1 2 3 4 5 6 7
{ "Principal": "exampleID", "Resource": "*", "Action": "PutObject", "Effect": "Allow", "Condition": { "StringLike": {"SourceVpc": "vpc-*"}} }
- In an ACL, if the granted entity is Everyone, the authorized account ID contains a wildcard character, or either public-read, public-read-write, public-read-delivered or public-read-write-delivered is configured, the ACL allows public access.
Example 1: Configure a bucket ACL to allow public access in its header.
1 2 3 4 5 6 7
PUT /?acl HTTP/1.1 Authorization: OBS H4IPJX0TQTHTHEBQQCEC:iqSPeUBl66PwXDApxjRKk6hlcN4= User-Agent: curl/7.29.0 Host: examplebucket.obs.region.myhuaweicloud.com x-obs-acl: public-read Date: WED, 01 Jul 2015 02:37:22 GMT Content-Type: application/xml
Example 2: Configure a bucket ACL to allow public access in its body.
1 2 3 4 5 6 7 8 9 10 11 12 13
<AccessControlPolicy xmlns="http://obs.cn-north-4.myhuaweicloud.com/doc/2024-12-30/"> <Owner> <ID>b4bf1b36d9ca43d984fbcb9491b6fce9</ID> </Owner> <AccessControlList> <Grant> <Grantee> <Canned>Everyone</Canned> </Grantee> <Permission>READ_ACP</Permission> </Grant> </AccessControlList> </AccessControlPolicy>
Block Public Access Settings
OBS provides four Block Public Access settings. You can use them in any combination and apply them to buckets.
| Setting | Description |
| BlockPublicAcls | Enabling this setting will:
| BlockPublicPolicy | Enabling this setting will prevent creating or modifying a bucket policy that contains public access. |
| IgnorePublicAcls | Enabling this setting will:
For example, if IgnorePublicAcls is enabled for bucket A, you can configure an ACL for object b to allow public access either during its upload to bucket A or after the upload is complete. |
| RestrictPublicBuckets | Enabling this setting will invalidate any bucket policy that contains public access. Afterward, only the bucket owner account and its IAM users can access the bucket and objects within. |
Important Notes
- Before enabling Block Public Access, verify that your services can work correctly without public access.
- To block public access, your account must have the PutBucketPublicAccessBlock permission.
- If Block Public Access is enabled for a bucket, OBS returns all ACL rules on the bucket when you obtain the ACL of the bucket or any object it contains. For example, if IgnorePublicAcls is enabled for a bucket with an ACL that allows public access, obtaining the bucket's ACL will still show the ACL rule that allows public access.
- Enabling Block Public Access does not affect existing bucket policies or ACLs. Therefore, disabling the Block Public Access settings will make any bucket or object with a public bucket policy or ACL publicly accessible again.
- By default, Block Public Access (four settings in Table 2) is enabled for newly created buckets but disabled for newly created parallel file systems. Enabling it for parallel file systems may degrade performance. For existing buckets, Block Public Access is disabled by default and must be manually enabled if needed.
- You can block public access only for buckets, not for accounts or specified objects.
- To ensure that Block Public Access can work appropriately, the total size of all bucket policies cannot exceed 20 KB, and the combined size of all ACLs and bucket policies cannot exceed 32 KB. If the size exceeds the upper limit, requests for setting bucket policies or bucket ACLs, querying the public status of buckets, and enabling Block Public Access may be denied, with error code 400 and message "Bucket policy and bucket acl is too large/complicated to perform block public access analysis" returned.
- Block Public Access is not available for mirroring-based back to source scenarios.
- During cross-region replication, if the destination bucket has the BlockPublicAcls setting, objects with public ACLs in the source bucket will fail to be replicated.
- To use Block Public Access, you must have the following permissions.
Table 3 Permissions required for using Block Public Access Operation
Required Permissions
Configuring Block Public Access for a bucket
Bucket owner or a user with the PutBucketPublicAccessBlock permission
Obtaining the Block Public Access configuration of a bucket
Bucket owner or a user with the GetBucketPublicAccessBlock permission
Deleting the Block Public Access configuration of a bucket
Bucket owner or a user with the DeleteBucketPublicAccessBlock permission
Obtaining the public access status of a bucket policy
Bucket owner or a user with the GetBucketPolicyPublicStatus permission
Bucket owner or a user with the GetBucketPublicStatus permission
Ways to Use Block Public Access
You can use Block Public Access through OBS Console, SDKs, or APIs.
Helpful Links
