Configuring Static Website Hosting (SDK for Java)
Function
You can host static website resources such as HTML web pages, flash files, or audio and video files in an OBS bucket, so that you can provide these hosted resources using the bucket's website endpoint to end users. Typical use cases include:
- Redirecting all requests to another website
- Redirecting specific requests to another website
This API configures static website hosting for a bucket.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- Periods (.) should be avoided in the target bucket name, or there may be certificate verification failures on the client when you use HTTPS for access.
- The request body of the website configuration cannot exceed 10 KB.
- To configure static website hosting for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketWebsite in IAM or PutBucketWebsite in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.setBucketWebsite(final SetBucketWebsiteRequest request)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
request |
Yes |
Explanation: Request parameters for configuring website hosting. For details, see Table 2. |
Parameter |
Type |
Description |
bucketName |
String |
Yes |
Explanation: Bucket name. Restrictions:
Value range: The value must contain 3 to 63 characters. |
websiteConfig |
Yes |
Explanation: Static website hosting configurations. For details, see Table 3. |
Parameter |
Type |
Description |
suffix |
String |
No |
Explanation: Suffix that is appended to the request for a directory. For example, if the suffix is index.html and you request samplebucket/images/, the returned data will be for the object named images/index.html in the bucket samplebucket. Restrictions:
Value range: This parameter can neither be left blank nor contain slashes (/). Default value: None |
key |
String |
No |
Explanation: Object name to use when a 4XX error occurs. This parameter specifies the web page to display when an error occurs. Restrictions:
Value range: The value must contain 1 to 1,024 characters. Default value: None |
routeRules |
List<RouteRule> |
No |
Explanation: List of routing rules. For details, see Table 6. Restrictions:
redirectAllRequestsTo |
No |
Explanation: Redirection rules for all requests. For details, see Table 4. Restrictions:
Parameter |
Type |
Description |
hostName |
String |
Yes |
Explanation: Host name used for redirection, for example, www.example.com. Restrictions: The host name must comply with the host name rules. Default value: None |
protocol |
No |
Explanation: Protocol used for redirection. Value range: See Table 5. Default value: None |
Constant |
Default Value |
Description |
HTTP |
http |
HTTP protocol used for redirection. |
HTTPS |
https |
HTTPS protocol used for redirection. |
Parameter |
Type |
Description |
condition |
No |
Explanation: Conditions of a redirection rule. For details, see Table 7. |
redirect |
Yes |
Explanation: Details about the redirection. For details, see Table 8. |
Parameter |
Type |
Description |
keyPrefixEquals |
String |
No |
Explanation: Object name prefix for the redirection to take effect. If the name prefix of the requested object is the same as the value specified for this parameter, the redirection rule takes effect. For example, to redirect the requests for the object ExamplePage.html, set keyPrefixEquals to ExamplePage.html. Restrictions: This parameter cannot be used together with httpErrorCodeReturnedEquals. Value range: The value must contain 1 to 1,024 characters. Default value: None |
httpErrorCodeReturnedEquals |
String |
No |
Explanation: HTTP error code for the redirection to take effect. If there is an error, and the error code returned is the same as the value specified for this parameter, the redirection rule takes effect. For example, if you want to redirect requests to NotFound.html when HTTP error code 404 is returned, set httpErrorCodeReturnedEquals to 404 in RouteRuleCondition, and set replaceKeyWith to NotFound.html in Redirect. Restrictions: This parameter cannot be used together with keyPrefixEquals. Value range: See Error Codes. Default value: None |
Parameter |
Type |
Description |
Protocol |
No |
hostName |
String |
No |
Explanation: Host name used for redirection. Default value: None |
replaceKeyPrefixWith |
String |
No |
Explanation: Object name prefix used in the redirection request. Restrictions: This parameter cannot be used together with replaceKeyWith. Value range: The value must contain 1 to 1,024 characters. Default value: None |
replaceKeyWith |
String |
No |
Explanation: Object name used in the redirection request. Restrictions: This parameter cannot be used together with replaceKeyPrefixWith. Value range: The value must contain 1 to 1,024 characters. Default value: None |
httpRedirectCode |
String |
No |
Explanation: HTTP status code in the response to the redirect request. For details, see Status Code. Default value: None |
Responses
Parameter |
Type |
Description |
statusCode |
int |
Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
responseHeaders |
Map<String, Object> |
Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
Code Example: Configuring the Default Home Page and Error Pages
This example configures the default homepage and error pages for bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 |
import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.WebsiteConfiguration; public class SetBucketWebsite001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Sample code is as follows: WebsiteConfiguration config = new WebsiteConfiguration(); // Configure the default homepage. config.setSuffix("index.html"); // Configure the error pages. config.setKey("error.html"); obsClient.setBucketWebsite("examplebucket", config); System.out.println("setBucketWebsite successfully"); } catch (ObsException e) { System.out.println("setBucketWebsite failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("setBucketWebsite failed"); // Print other error information. e.printStackTrace(); } } } |
Code Example: Configuring a Redirection Rule
This example configures a redirection rule for bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 |
import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.ProtocolEnum; import com.obs.services.model.Redirect; import com.obs.services.model.RouteRule; import com.obs.services.model.RouteRuleCondition; import com.obs.services.model.WebsiteConfiguration; public class SetBucketWebsite002 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Sample code is as follows: WebsiteConfiguration config = new WebsiteConfiguration(); // Configure the default homepage. config.setSuffix("index.html"); // Configure the error pages. config.setKey("error.html"); RouteRule rule = new RouteRule(); Redirect r = new Redirect(); r.setHostName("www.example.com"); r.setHttpRedirectCode("305"); r.setRedirectProtocol(ProtocolEnum.HTTP); r.setReplaceKeyPrefixWith("replacekeyprefix"); rule.setRedirect(r); RouteRuleCondition condition = new RouteRuleCondition(); condition.setHttpErrorCodeReturnedEquals("404"); condition.setKeyPrefixEquals("keyprefix"); rule.setCondition(condition); config.getRouteRules().add(rule); obsClient.setBucketWebsite("examplebucket", config); System.out.println("setBucketWebsite successfully"); } catch (ObsException e) { System.out.println("setBucketWebsite failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("setBucketWebsite failed"); // Print other error information. e.printStackTrace(); } } } |
Code Example: Configuring Redirection for All Requests
This example configures redirection of all requests for bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 |
import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.ProtocolEnum; import com.obs.services.model.RedirectAllRequest; import com.obs.services.model.WebsiteConfiguration; public class SetBucketWebsite003 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Sample code is as follows: WebsiteConfiguration config = new WebsiteConfiguration(); RedirectAllRequest redirectAll = new RedirectAllRequest(); redirectAll.setHostName("www.example.com"); redirectAll.setRedirectProtocol(ProtocolEnum.HTTP); config.setRedirectAllRequestsTo(redirectAll); obsClient.setBucketWebsite("examplebucket", config); System.out.println("setBucketWebsite successfully"); } catch (ObsException e) { System.out.println("setBucketWebsite failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("setBucketWebsite failed"); // Print other error information. e.printStackTrace(); } } } |
