Obtaining the Policy of a Bucket (SDK for Java)
Function
OBS provides access control over buckets. You can use an access policy to define whether a user can perform certain operations on a specific bucket. OBS access control can be implemented using IAM permissions, bucket policies, and ACLs. For more information, see Introduction to OBS Access Control.
This API returns the policy of a bucket.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- OBS returns 404 NoSuchBucketPolicy when you call this API in the following scenarios:
- The specified bucket policy does not exist.
- The standard policy of the specified bucket is set to Private and no advanced policies are configured.
- To obtain the policy of a bucket, you must be the bucket owner or the bucket owner's IAM user with the required permission (obs:bucket:GetBucketPolicy in IAM or GetBucketPolicy in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.getBucketPolicy(String bucketName)
Request Parameters
Parameter | Type | Mandatory (Yes/No) | Description |
bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
Responses
Parameter | Type | Description |
policy | String | Explanation: Policy information in JSON format Restrictions:
Code Examples
This example returns the policy of bucket exampleBucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; public class GetBucketPolicy001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Example bucket name String exampleBucket = "examplebucket"; String policy = obsClient.getBucketPolicy(exampleBucket); System.out.println("\t" + policy); } catch (ObsException e) { System.out.println("GetBucketAcl failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("GetBucketAcl failed"); // Print other error information. e.printStackTrace(); } } } |
