Help Center/ Elastic Cloud Server/ User Guide/ Instances/ Purchasing an ECS/ Purchasing an ECS in Custom Config Mode
Updated on 2026-04-24 GMT+08:00
Elastic Cloud Server (ECS) is a cloud server that provides scalable, on-demand resources, including vCPUs, memory, OS, and Elastic Volume Service (EVS) disks. After purchasing an ECS, you can use it like using your local computer or physical server.
You can create an ECS by specifying its vCPUs, memory, OS, specifications, and login mode.
This section describes how to create an ECS on the management console.
Step
Preparations
  • Sign up for a HUAWEI ID, enable Huawei Cloud services, and top up your account.
  • Prepare resources, such as VPCs, subnets, security groups, key pairs, Dedicated Computing Cluster (DCC), and CloudPond.
Step 1: Access the Page for Purchasing ECSs
Log in to the ECS console and open the page for purchasing ECSs.
Step 2: Specify Parameters
Specify parameters based on your service requirements.
Step 3: Confirm the Configuration and Submit the Order
Confirm the configuration details and complete the purchase.
Preparations
  1. Sign up for a HUAWEI ID and complete real-name authentication.
    Before purchasing an ECS, sign up for a HUAWEI ID, enable Huawei Cloud services, and complete real-name authentication first.
    If you have enabled Huawei Cloud services and completed real-name authentication, skip this step.
  2. Top up your account.
    Ensure that your account has sufficient balance or has a valid payment method configured. If not, top up your account.
  3. Plan network resources, such as VPCs and subnets.
    When you purchase an ECS, the system creates a default VPC (vpc-default) and subnet (subnet-default).
    If you do not want to use the default VPC and subnet, you can create a VPC and subnet in the corresponding region in advance. For more details, see VPC and Subnet Planning.
  4. Create a security group and add rules to it.
    When you purchase an ECS, the system creates default security groups (default, Sys-WebServer, and Sys-FullAccess). For more information about security groups and rules, see Default Security Group and Rules.
    If the default security groups and rules cannot meet your service requirements, you can modify them. For details, see Configuring Security Group Rules.
  5. Create a key pair.
    To log in to the ECS using a key pair, create one in advance. For details, see (Recommended) Creating a Key Pair on the Management Console.
  6. Create dedicated physical resources.
    To make your ECSs run on isolated physical hardware, apply for a Dedicated Computing Cluster (DCC) before creating the ECSs.
    For details, see Applying for a DCC.
  7. Register an edge site.
    To create ECSs for CloudPond sites, register an edge site in advance.
    For details, see Registering an Edge Site.
Go to the Buy ECS page. On the displayed page, click the Custom Config tab in the upper left corner.
Figure 1 Custom config
Specify parameters required for purchasing an ECS. These parameters include but are not limited to the billing mode, region, AZ, specifications, storage, and network.
  1. In the Configuration Summary panel on the right side, confirm the ECS details.
    Mandatory fields that are not configured are displayed in red. You need to set them in the parameter configuration area.
  2. (Optional) Click Save as Launch Template.
    Perform this step only when you need to create an ECS using a launch template. For details, see Purchasing ECSs Using Auto Launch Groups.
    The configuration cannot be saved as a launch template if the billing mode is yearly/monthly or spot block, host security is enabled, or the login mode is password.
  3. Read and agree to the agreement, and click Submit.
    After the ECS is created, it will be started by default.
  4. Click back to ECS list. You can view the created ECS on the ECS list page.
Follow-up Procedure
  • Using an ECS
    After purchasing an ECS, you can build environments, websites, or applications on it. For details, see Best Practices Summary.
