Authorizing API Access
APIs using app authentication can only be called by credentials that have been authorized to call them.
![](https://support.huaweicloud.com/intl/en-us/ae-ad-1-usermanual-apig/public_sys-resources/notice_3.0-en-us.png)
- You can authorize credentials only to call APIs that use app authentication.
- A credential can be authorized to access a maximum of 1000 APIs.
- You have published an API.
- You have created an environment.
- You have created a credential.
- Log in to the APIG console.
- Select a gateway at the top of the navigation pane.
- Choose API Management > API Groups.
- Click a group name.
- On the APIs tab, select the target API and choose More > Authorize Credentials.
- Click Select Credentials.
- Select an environment, search for and select desired credentials, and click OK. The authorized credentials are displayed on the Authorize Credentials page.
To cancel the authorization of a credential, click Cancel Authorization in the Operation column that contains the credential.
Follow-Up Operations
After you authorize a credential for an API, the API can be called by the credential using SDKs of different programming languages.
