Help Center>
API Gateway>
User Guide (ME-Abu Dhabi Region)>
FAQs>
API Publishing>
Do I Need to Publish an API Again After Modification?
Updated on 2023-05-09 GMT+08:00
Yes. After you modify the parameters of a published API, you must publish the API again to synchronize the modifications to the environment.
Parent topic: API Publishing
