Help Center/ API Gateway/ User Guide (Kuala Lumpur Region)/ Getting Started/ Calling APIs/ Creating a Credential and Getting Authorized
Updated on 2024-08-07 GMT+08:00
  1. In the navigation pane, choose API Management > Credentials.
  2. Click Create Credential and set credential information.
    Table 1 Credential information
    Name
    Credential name. It is recommended that you enter a name based on naming rules to facilitate search.
    Description about the credential.
  3. Click OK.
Binding to an API
  1. In the Operation column of the created credential, click Bind to APIs. Note that only APIs that use app authentication can be bound.
  2. Select the environment, API group, and API created in Opening APIs, and click OK.
