Process Flow
The following figure shows the process of calling an API.
- Obtaining an API
- Creating a Credential and Getting Authorized
APIs that use app authentication can only be called using credentials bound to them.
- Adding an AppCode for Simple Authentication
API Gateway only verifies the AppCode during simple authentication.
- Calling an API
Use an API test tool to call the API with the simple authentication AppCode.
