Help Center/
API Gateway/
User Guide (Kuala Lumpur Region)/
FAQs/
API Calling/
How Do I Switch the Environment for API Calling?
Updated on 2024-08-07 GMT+08:00
By default, the API in the RELEASE environment is called.
If you want to call the same API in another environment, add the request header X-Stage to specify the environment name.
Parent topic: API Calling
