x-apigateway-cors
Meaning: Specifies whether CORS is supported. The value is of the Boolean type.
Scope of effect: Operation Object (2.0)/Operation Object (3.0)
Example:
paths:
  '/path':
    get:
      x-apigateway-cors: true
Table 1 Parameter description
Mandatory
Type
x-apigateway-cors
Yes
boolean
Whether to support CORS.
  • true: support
  • false: not support
For the API request for enabling CORS, the headers listed in the following table will be added to the response.
Header
Value
Access-Control-Max-Age
172800
Maximum time the response of a preflight request can be cached.
Unit: s
Access-Control-Allow-Origin
Requests from any domain are allowed.
Access-Control-Allow-Headers
X-Sdk-Date, X-Sdk-Nonce, X-Proxy-Signed-Headers, X-Sdk-Content-Sha256, X-Forwarded-For, Authorization, Content-Type, Accept, Accept-Ranges, Cache-Control, and Range
Headers that can be used by a formal request.
Access-Control-Allow-Methods
GET, POST, PUT, DELETE, HEAD, OPTIONS, and PATCH
Methods that can be used by a formal request.
