x-apigateway-is-send-fg-body-base64
Meaning: Whether to perform Base64 encoding on the request body used for interaction with FunctionGraph. The value is of the Boolean type.
Scope of effect: Operation Object (2.0)/Operation Object (3.0)
Example:
paths:
  '/path':
    get:
      "x-apigateway-is-send-fg-body-base64": true
Table 1 Parameter description
Mandatory
Type
No
boolean
Specifies whether to perform Base64 encoding on the request body for interaction with FunctionGraph.
  • true: yes
  • false: no
