Viewing or Modifying Gateway Information
You can view and modify the configuration of your gateways on the console.
- Go to the APIG console.
- In the navigation pane, choose Gateways.
- Click Access Console or the name of the target gateway.
- On the Gateway Information tab, view or modify the configuration of the gateway.
Table 1 Gateway information Modifiable Parameter
Basic Information
Basic information about the gateway, including the name, ID, edition, AZ, description, enterprise project, and maintenance time window.
- You can modify the basic information as required.
- To copy the gateway ID, click
next to the ID.
Billing Mode
Billing mode of the gateway and the time when the gateway is created.
Network
- VPC
VPC associated with the gateway. Click the VPC name to view the configuration.
- Subnet
Subnet associated with the gateway. Click the subnet name to view the configuration.
- Security Group
Security group associated with the gateway. Click the security group name to view the configuration or click
to bind a new one. - Access Control
APIG provides access control policies to gateways. You can set an IP address blacklist or whitelist to forbid or allow an IP address to access a gateway. The IP addresses are described as follows:
- Common IP address, for example, 127.0.0.1.
- IP address with a mask, for example, 192.145.0.0/16.
- IP address segment, for example, 127.0.0.1-192.145.0.1.
An access control policy supports a maximum of 100 IP addresses or segments, with the maximum length of 5,120 characters.
Before entering an IPv6 address, ensure the gateway supports IPv6 access.
If Status is disabled, access from all IP addresses is allowed by default. If Status is enabled and no IP address is configured in Whitelist, access from any IP address is denied. If Status is enabled and no IP address is configured in Blacklist, access from any IP address is allowed.
For security group policies, and gateway and API access control policies, the "Deny" settings take precedence over the "Allow" settings.
Address Management
- Inbound Access
- VPC Access Address
You can click
next to a connection address to copy the address. - EIP
- To bind an EIP to the gateway, click Enable.
- If an EIP has been bound to the gateway, you can click
on the right of the address to copy the address information or click Unbind EIP on the right of the address to unbind the EIP.
- Bandwidth
If an EIP has been bound to the gateway, you can modify the bandwidth size. It is billed by bandwidth based on the rate of the EIP service.
- Outbound Access
Determine whether to allow backend services of the APIs created in the gateway to be deployed on public networks. You can enable or disable outbound access at any time.
After enabling outbound access, you can click View Metrics to view the monitoring data, or modify the bandwidth as required.
- Billing Mode
The Billing Mode area displays the bandwidth billing information. You can pay for EIPs by fixed bandwidth size. If you select billed by fixed bandwidth, you need to pay for the fixed bandwidth.
- Decreasing bandwidths may cause packet loss. Exercise caution when performing this operation.
Routes
Configure a private network segment that needs to communicate with the gateway. After a gateway is created, it can communicate with the VPC subnet specified during gateway creation by default.
Configure routes at your premises if the subnet of your data center is within the following three segments:
- 10.0.0.0/8-24
- 172.16.0.0/12-24
- 192.168.0.0/16-24
