Help Center/ API Gateway/ User Guide/ Creating a Gateway
Updated on 2026-02-11 GMT+08:00
Creating a Gateway
This section describes how to create a gateway. You can create APIs and provide services only after the gateway is created.
Notes and Constraints
  • Permissions
    • You must be assigned both the APIG Administrator and VPC Administrator roles so that you can create gateways.
    • Alternatively, you must be attached the APIG FullAccess policy.
    • You can also be granted permissions using custom policies. For details, see Using IAM to Grant Access to APIG.
  • Gateway
    By default, your account can be used to create five gateways in a project. To create more dedicated gateways, submit a service ticket to increase the quota.
  • Network
    If you use 192.x.x.x or 10.x.x.x, APIG uses 172.31.32.0/19 as the internal subnet. If you use 172.x.x.x, APIG uses 192.168.32.0/19 as the internal subnet.
  • Number of available private IP addresses in the subnet
    The basic, professional, enterprise, and platinum editions of APIG require 3, 5, 6, and 7 private IP addresses. A platinum X requires 4 more private IP addresses than the previous edition. For example, platinum 2 requires 11 private addresses, and platinum 4 requires 19 private addresses. Check that the subnet you choose has sufficient private IP addresses on the VPC console.
  • Workload
    VPCs (workloads) where gateways have been deployed cannot be changed.
  • Security group
    Security groups do not take effect after gateways are purchased in regions except LA-Mexico City1 and CN North-Beijing1. To disable access from specific IP addresses, see Configuring API Access Control.
Preparing the Network Environment
  • Workload
    Gateways are deployed in VPCs (workloads). Cloud resources, such as Elastic Cloud Servers (ECSs), in the same workload can call APIs using the private IP address of the gateway deployed in the workload.
    You are advised to deploy your gateways in the same workload as your other services to facilitate network configuration and secure network access.
  • Security group
    Similar to a firewall, a security group controls access to a gateway through a specific port and transmission of communication data from the gateway to a specific destination address. For security purposes, create inbound rules for the security group to allow access only on specific ports.
    The security group bound to a gateway must meet the following requirements:
    • Inbound access: Enable the 1026 (TCP) port of the VPC CIDR block associated with the gateway.
    • Inbound access: To allow the APIs in the gateway to be accessed over public networks or from other security groups, configure inbound rules for the security group to allow access on ports 80 (HTTP), 443 (HTTPS), and 1026.
    • Outbound access: If the backend service of an API is deployed on a public network or in another security group, add outbound rules for the security group to allow access to the backend service address through the API calling port.
    • If the frontend and backend services of an API are bound with the same security group and VPC as the gateway, no inbound or outbound rules are needed to allow access through the preceding ports.
Creating a Gateway
  1. Go to the Buy Gateway page.
  1. Set the gateway parameters by referring to the following table.
    Table 1 API gateway parameters
    Billing Mode
    Billing mode of the dedicated gateway. Options: Pay-per-use.
    Region
    A geographic area where the gateway will be deployed. Deploy the gateway in the same region as your other services to allow all services to communicate with each other through subnets within a workload. This reduces public bandwidth costs and network latency.
    AZ
    Select the availability zone (AZ) where the gateway resides. Different AZs are physically isolated but can communicate with each other via a private network.
    • To enhance gateway availability, deploy the gateway in multiple AZs.
    • APIG does not support gateway migration across AZs.
      To create a single-AZ gateway, create two gateways in at least two AZs to improve service reliability. Otherwise, services will be unavailable if one AZ is faulty.
    Gateway Name
    Gateway name, which can be customized. The value must start with a letter and consist of 3 to 64 characters, including letters, digits, hyphens (-), and underscores (_).
    Edition
    The basic, professional, enterprise, and platinum editions are available for gateways. The number of concurrent requests allowed varies depending on the gateway edition. For more information, see Specifications.
    Currently, platinum edition 2 and later are available only in CN North-Beijing4, CN East2, ME-Riyadh, and CN-Hong Kong.
    Scheduled Maintenance
    Time period when technical support engineers can maintain the gateway. The technical support personnel will contact you before maintenance.
    Select a time period with low service demands.
    Enterprise Project
    Select an enterprise project to which the gateway belongs. This parameter is available only if your account is an enterprise account.
    For details about resource usage, migration, and user permissions of enterprise projects, see Enterprise Management User Guide.
    Public Inbound Access
    Determine whether to allow the APIs created in the gateway to be called by external services using an EIP. If the feature is enabled, an EIP is bound by default. You will need to pay for the EIP usage. And you can set a bandwidth that meets your service requirements.
    • Gateways with Public Inbound Access enabled in regions except LA-Mexico City1 and CN North-Beijing1 are randomly assigned an EIP and cannot use an existing EIP. Set a bandwidth that meets your service requirements for public inbound access. The bandwidth will be billed by hour based on the pricing of the EIP service.
    • APIs in the gateway can be called using independent or debugging domain names. There is a limit on the number of times that APIs in an API group can be called per day using the debugging domain name. To overcome the limitation, bind independent domain names to the API group and ensure that the domain names have already been CNAMEd to the EIP of the gateway to which the API group belongs.
      For example, you have an HTTPS API (path: /apidemo) with public access enabled. The API can be called using "https://{domain}/apidemo", where {domain} indicates an independent domain name bound to the group of the API. The default port is 443.
    Public Outbound Access
    Determine whether to allow backend services of the APIs created in the gateway to be deployed on public networks. Set a bandwidth that meets your service requirements for public outbound access. The bandwidth will be billed by hour based on the pricing of the EIP service.
    Network
    Select a VPC and subnet for the dedicated gateway.
    • Select the created VPC and subnet from the drop-down list.
    • Select the shared VPC and subnet from the drop-down list.
      VPC owners can share the subnets in a VPC with one or multiple accounts through Resource Access Manager (RAM). Through VPC sharing, you can easily configure and manage multiple accounts' resources at low costs. For more information about VPC subnet sharing, see VPC Sharing.
    • Create a VPC and subnet by clicking Create VPC. For details, see Creating a VPC.
    Security Group
    Select a security group to control inbound and outbound access.
    If the backend service of an API is deployed on an external network, configure security group rules to allow access to the backend service address through the API calling port.
    If public inbound access is enabled, add inbound rules for the security group to allow access on ports 80 (HTTP) and 443 (HTTPS).
    • Only the security groups configured in the LA-Mexico City1 and CN North-Beijing1 regions take effect. For other regions, ELB load balancing is enabled by default after gateway purchase. To disable access from specific IP addresses, use access control policies.
    • ELB functions as a load balancer for gateways, which support cross-VPC access. Gateways with public inbound access enabled are randomly assigned an EIP and cannot use an existing EIP.
    VPC Endpoint Service
    Name of a VPC endpoint service to create when you buy the gateway. The gateway then can be accessed using the endpoint service.
    If a name is specified, the VPC endpoint service name to display on the VPC Endpoints tab will be in the format "{region}.{Specified VPC endpoint service name}.{VPC endpoint service ID}". If no name is specified, the displayed name will be in the format "{region}.apig.{VPC endpoint service ID}".
    Tags
    Tags classify your gateways to facilitate search, analysis, and management. If no tag is available, click View predefined tags or enter a tag key and value to create one.
    Alternatively, set tags on the Tag Management Service (TMS) console by referring to Configuring Gateway Tags.
    If your organization has configured tag policies for APIG, add tags to gateways based on the policies. If a tag does not comply with the policies, gateway creation may fail. Contact your organization administrator to learn more about tag policies.
    Gateway description. Enter 1 to 255 characters.
  2. Click Next.
  3. Confirm the gateway configurations, read and confirm your acceptance of the service agreement, and click Pay Now. The gateway is created with the status displayed on the screen.
Related Documents
After the gateway is created, you can create and manage APIs in this gateway. For details, see Process Flow.
