Why Doesn't Modification of the backend_timeout Parameter Take Effect?
Problem Description
Modification of the backend_timeout parameter in a dedicated gateway does not take effect.
Possible Causes
The Timeout (ms) parameter on the Define Backend Request page is not modified.
Solution
Log in to the APIG console, go to the API details page, click Edit, and modify the Timeout (ms) parameter on the Define Backend Request page.
