APIG Operations Recorded by CTS
Enabling CTS
If you want to collect, record, or query operation logs for APIG in common scenarios such as security analysis, audit, and problem locating, enable Cloud Trace Service (CTS). For details, see section "Enabling CTS" in the Cloud Trace Service User Guide.
CTS provides the following functions:
  • Recording audit logs
  • Querying audit logs
  • Dumping audit logs
  • Encrypting trace files
  • Enabling notifications of key operations
Viewing Key Operations
With CTS, you can record operations associated with APIG for future query, audit, and backtracking.
Table 1 APIG operations recorded by CTS
Operation
Resource Type
Trace Name
Creating an API group
ApiGroup
createApiGroup
Modifying an API Group
ApiGroup
updateApiGroup
Deleting an API group
ApiGroup
deleteApiGroup
Verifying an API group name
Swagger
CheckApiGroups
Creating an environment
Environment
createEnvironment
Modifying an environment
Environment
updateEnvironment
Deleting an environment
Environment
deleteEnvironment
Creating a variable
EnvVariable
CreateEnvironmentVariable
Deleting a variable
EnvVariable
DeleteEnvironmentVariable
Modifying a variable
EnvVariable
UpdateEnvironmentVariable
Creating a request throttling policy
Throttle
CreateRequestThrottlingPolicy
Modifying a request throttling policy
Throttle
UpdateRequestThrottlingPolicy
Deleting a request throttling policy
Throttle
DeleteRequestThrottlingPolicy
Creating an API
Api
CreateApi
Modifying an API
Api
UpdateApi
Deleting an API
Api
DeleteApi
Publishing an API or taking an API offline
Api
CreateOrDeletePublishRecordForApi
Verifying the API definition
Api
CheckApis
Debugging an API
Api
DebugApi
Publishing multiple APIs or taking APIs offline
Api
BatchPublishOrOfflineApi
Switching API versions
Api
ChangeApiVersion
Taking an API version offline
Api
DeleteApiByVersionId
Creating a signature key
Signature
CreateSignatureKey
Modifying a signature key
Signature
UpdateSignatureKey
Deleting a signature key
Signature
DeleteSignatureKey
Binding a signature key
SignatureBinding
AssociateSignatureKey
Unbinding a signature key
SignatureBinding
DisassociateSignatureKey
Binding a request throttling policy
ThrottleBinding
AssociateRequestThrottlingPolicy
Unbinding a request throttling policy
ThrottleBinding
DisassociateRequestThrottlingPolicy
Unbinding multiple request throttling policies
ThrottleBinding
BatchDisassociateThrottlingPolicy
Creating a special request throttling configuration
ThrottleSpecial
CreateSpecialThrottlingConfiguration
Modifying a special request throttling configuration
ThrottleSpecial
UpdateSpecialThrottlingConfiguration
Deleting an excluded request throttling configuration
ThrottleSpecial
DeleteSpecialThrottlingConfiguration
Authorizing apps
AppAuth
CreateAuthorizingApps
Canceling authorization
AppAuth
CancelingAuthorization
Binding a domain name
ApiGroup
AssociateDomain
Adding a certificate to a domain name
ApiGroup
AssociateCertificate
Modifying a domain name
ApiGroup
UpdateDomain
Unbinding a domain name
ApiGroup
DisassociateDomain
Deleting a domain certificate
ApiGroup
DisassociateCertificate
Creating an access control policy
Acl
CreateAclStrategy
Modifying an access control policy
Acl
UpdateAclStrategy
Deleting an access control policy
Acl
DeleteAcl
Deleting multiple access control policies
Acl
BatchDeleteAclV2
Binding an access control policy to an API
AclBinding
CreateApiAclBinding
Unbinding an access control policy from an API
AclBinding
DeleteApiAclBinding
Unbinding multiple access control policies from APIs
AclBinding
BatchDeleteApiAclBinding
Creating a custom authorizer
Authorizer
CreateCustomAuthorizer
Modifying a custom authorizer
Authorizer
UpdateCustomAuthorizer
Deleting a custom authorizer
Authorizer
DeleteCustomAuthorizer
Exporting APIs
Swagger
ExportApiDefinitions
Importing APIs
Swagger
ImportApiDefinitions
Creating a VPC channel
Vpc
CreateVpcChannel
Updating a VPC channel
Vpc
UpdateVpcChannel
Deleting a VPC channel
Vpc
DeleteVpcChannel
Adding or updating backend instances
Vpc
AddingBackendInstances
Updating backend instances
Vpc
UpdateBackendInstances
Removing a backend server
Vpc
DeleteBackendInstance
Enabling backend servers
Vpc
BatchEnableMembers
Disabling backend servers
Vpc
BatchDisableMembers
Modifying VPC channel health check
Vpc
UpdateHealthCheck
Adding or updating a backend server group of a VPC channel
Vpc
CreateMemberGroup
Deleting a backend server group of a VPC channel
Vpc
DeleteMemberGroup
Updating a Backend Server Group of a VPC Channel
Vpc
UpdateMemberGroup
Creating a response for an API group
ApiGroup
CreateGatewayResponse
Modifying a response of an API group
ApiGroup
UpdateGatewayResponse
Deleting a response of an API group
ApiGroup
DeleteGatewayResponse
Modifying the response of an error type defined for an API group
ApiGroup
UpdateGatewayResponseType
Deleting the response of an error type defined for an API group
ApiGroup
DeleteGatewayResponseType
Configuring a feature for a gateway
Feature
CreateFeatureV2
Creating a dedicated gateway (Pay-per-use)
Instance
CreateInstance
Updating a dedicated gateway
Instance
UpdateInstance
Binding an EIP to a gateway or updating the EIP of a gateway
Instance
AddEip
Unbinding the EIP of a gateway
Instance
RemoveEip
Enabling public outbound access for a gateway
Instance
AddEngressEip
Updating the public outbound access bandwidth of a gateway
Instance
UpdateEngressEip
Disabling public outbound access for a gateway
Instance
RemoveEngressEip
Enabling public inbound access
Instance
AddIngressEip
Updating the public inbound access bandwidth of a gateway
Instance
UpdateIngressEip
Disabling public inbound access for a gateway
Instance
RemoveIngressEip
Deleting a dedicated gateway
Instance
DeleteInstances
Modifying the specifications of a pay-per-use gateway
Instance
CreatePostPayResizeOrder
Accepting or rejecting a VPC endpoint connection
vpc-endpoint
AcceptOrRejectEndpointConnections
Adding whitelist records for a VPC endpoint service
vpc-endpoint
AddEndpointPermissions
Deleting whitelist records of a VPC endpoint service
vpc-endpoint
DeleteEndpointPermissions
Batch adding or deleting gateway tags
Instance
BatchCreateOrDeleteInstanceTags
Importing a microservice
Microservice
ImportMicroservice
Adding an SSL certificate
SslCertificate
CreateCertificate
Binding a domain name with SSL certificates
ApiGroup
BatchAssociateCerts
Unbinding the SSL certificates of a domain name
ApiGroup
BatchDisassociateCerts
Deleting an SSL certificate
SslCertificate
DeleteCertificate
Modifying an SSL certificate
SslCertificate
UpdateCertificate
Binding an SSL certificate to a domain name
Certificate
BatchAssociateDomains
Unbinding an SSL certificate from a domain name
Certificate
BatchDisassociateDomains
Creating a plug-in
Plugin
CreatePlugin
Modifying a plug-in
Plugin
UpdatePlugin
Deleting a plug-in
Plugin
DeletePlugin
Binding a plug-in to an API
Plugin
AttachApiToPlugin
Plugin
AttachPluginToApi
Unbinding an API from a plug-in
Plugin
DetachApiFromPlugin
Unbinding a plug-in from an API
Plugin
DetachPluginFromApi
Creating an app
App
CreateAnApp
Modifying an app
App
UpdateApp
Deleting an app
App
DeleteAppV2
Resetting an Appsecret
App
ResettingAppSecret
Verifying an app
App
CheckApp
Creating an AppCode
AppCode
CreateAppCode
Generating an AppCode
AppCode
CreateAppCodeAuto
Deleting an AppCode
AppCode
DeleteAppCode
Configuring access control settings for an app
AppAcl
UpdateAppAcl
Deleting access control settings of an app
AppAcl
DeleteAppAcl
Creating a credential quota
AppQuota
CreateAppQuota
Modifying a credential quota
AppQuota
UpdateAppQuota
Deleting a credential quota
AppQuota
DeleteAppQuota
Binding a credential quota with credentials
AppQuotaBinding
AssociateAppsForAppQuota
Unbinding a credential quota from a credential
AppQuotaBinding
DisassociateAppQuotaWithApp
Disabling CTS
Disable CTS by following the procedure in section "Deleting a Tracker" in the Cloud Trace Service User Guide.
