Updated on 2026-07-02 GMT+08:00
Third-Party Authorizer
You can configure a third-party authorizer to connect your custom authentication service to API Gateway. Before calling a backend service, the gateway requests your authentication service for authentication. The gateway performs subsequent operations only after receiving a success response.
If this policy is not supported by your gateway, submit a service ticket to upgrade the gateway to the latest version.
The following figure shows the principle of third-party authentication. After binding a third-party authentication policy to an API, call the API by referring to Calling an Open API.
  • An API can be bound with only one third-party authorizer policy for a given environment, but each third-party authorizer policy can be bound to multiple APIs.
  • Policies are independent of APIs. A policy takes effect for an API only after they are bound to each other. When binding a policy to an API, you must specify an environment where the API has been published. The policy takes effect for the API only in the specified environment.
  • Taking an API offline does not affect the policies bound to it. The policies are still bound to the API if the API is published again.
  • Policies that have been bound to APIs cannot be deleted.
Creating a Third-Party Authorizer
  1. Go to the APIG console.
  2. Select a dedicated gateway at the top of the navigation pane.
  1. In the navigation pane, choose API Management > API Policies.
  2. On the Policies tab, click Create Policy.
  3. In the Select Policy Type box, select Third-Party Authorizer in the Plug-ins area.
  4. Set the policy information based on the following table.
    Table 1 Third-party authorizer parameters
    Name
    Enter a policy name. It is recommended that you enter a name based on naming rules to facilitate search.
    It can contain 3 to 255 characters and must start with a letter. Only letters, digits, and underscores (_) are allowed.
    Type
    Fixed value: Third-Party Authorizer.
    Description about the plug-in. Enter 1 to 255 characters.
    Policy Content
    Content of the plug-in, which can be configured in a form or using a script.
    Load Balance Channel
    Whether to connect a third-party authentication service using a load balance channel.
    Backend URL
    • Method
      GET, POST, PUT, and HEAD are supported.
    • Protocol
      HTTP or HTTPS. HTTPS is recommended for transmitting important or sensitive data.
    • Load Balance Channel (optional)
      Set this parameter only if a load balance channel is used. Select a load balance channel. If no required channel is available, click Create Load Balance Channel to create one.
    • Backend Address (optional)
      Set this parameter if no load balance channel is used.
      Enter the access address of the authentication service in the format of Host:Port. Host indicates the IP address or domain name for accessing the authentication service. If no port is specified, ports 80 and 443 are used by default for HTTP and HTTPS, respectively.
      Only IPv4 addresses are supported.
    • Path
      Path (URL) of the authentication service.
    Timeout (ms)
    Timeout of the authentication service. It cannot exceed the max. timeout of the backend service. View the timeout limit on the Parameters tab of the gateway details page.
    Host Header
    Host header field in the backend service request. By default, the original host header in each request is used.
    Brute Force Threshold
    IP addresses whose number of third-party authentication failure attempts within 5 minutes exceeds this threshold will be blocked. They will be unblocked after 5 minutes.
    For example, if an IP address has failed third-party authentication more than the configured threshold in the third minute, the address is blocked, and will be unblocked after 2 minutes.
    Identity Sources
    Parameters to obtain from the original API requests for third-party authentication. Max. 10 headers and 10 query strings. If not specified, all headers and query strings in the original requests will be used.
    Relaxed Mode
    When this option is enabled, APIG accepts client requests even when your authentication service cannot connect or returns an error code starting with "5".
    Allow Original Request Body
    When this option is enabled, the original request body is included for authentication.
    Request Body Size (bytes)
    Available only when Allow Original Request Body is enabled.
    The value cannot exceed the max. request body size of the gateway. View the request body size limit on the Parameters tab of the gateway details page.
    Allow Original Request Path
    When this option is enabled, the original request path is added to the end of the authentication request path.
    Return Response
    When this option is enabled, the authentication response is returned on failure.
    Allowed Response Headers
    Headers to obtain from the authentication response and send to the backend service, when the authentication is successful.
    Max. 10 headers.
    Simple Authentication
    When this option is enabled, status codes starting with "2" indicate successful authentication.
    Authentication Result
    Available only when Simple Authentication is disabled.
    Responses whose headers contain these parameters with the same values indicate successful authentication.
    Blacklist/Whitelist
    When this option is enabled, whether API requests require third-party authentication depends on the configured blacklist or whitelist rules.
    Type
    • Whitelist
      API requests matching the whitelist rules do not require third-party authentication.
    • Blacklist
      API requests matching the blacklist rules require third-party authentication.
    Parameters
    Define parameters for rule matching. For security purposes, do not include sensitive information in these parameters.
    • Parameter Location: the location of a parameter used for rule matching.
      • path: API request URI. This parameter is configured by default.
      • method: API request method. This parameter is configured by default.
      • header: the key of a request header.
      • query: the key of a query string.
      • system: a system parameter.
    • Parameter: the name of a parameter to match the specified value in a rule.
    Rules
    Define conditions for rule matching.
    Click Add Rule and edit the rule name and conditions. In the Condition Expressions dialog box, select a parameter and operator, and enter a value. For security purposes, do not include sensitive information in these parameters.
    • =: equal to
    • !=: not equal to
    • pattern: regular expression
    • enum: enumerated values. Separate them with commas (,).
  5. Click OK.
    • If the policy is displayed in the policy list, the policy is created successfully.
    • To clone this policy, click Clone in the Operation column. The name of a cloned policy cannot be the same as that of any existing policy.
  6. After the policy is created, perform the operations described in Binding the Policy to APIs to make the policy to take effect.
    After you bind a policy to an API, unbind the policy from the API, or update the policy, your settings will take effect immediately, without the need to publish the API.
Example Script
  "auth_request": {
    "method": "GET",
    "protocol": "HTTPS",
    "url_domain": "192.168.10.10",
    "timeout": 5000,
    "path": "/",
    "vpc_channel_enabled": false,
    "vpc_channel_info": null
  "custom_forbid_limit": 100,
  "carry_body": {
    "enabled": true,
    "max_body_size": 1000
  "auth_downgrade_enabled": true,
  "carry_path_enabled": true,
  "return_resp_body_enabled": false,
  "carry_resp_headers": [],
  "simple_auth_mode_enabled": true,
  "match_auth": null,
  "rule_enabled": false,
  "rule_type": "allow"
  1. Click the policy name to go to the policy details page.
  2. Select an environment and click Select APIs.
  3. Select the API group, environment, and required APIs.
    APIs can be filtered by API name or tag. The tag is defined during API creation.
  4. Click OK.
    • If an API no longer needs this policy, click Unbind in the row that contains the API.
    • If there are multiple APIs that no longer need this policy, select these APIs, and click Unbind above the API list. You can unbind a policy from a maximum of 1000 APIs at a time.
Related Documents
To create a third-party authorizer policy by calling an API, see Creating a Plug-in.
