Kafka Log Push
Kafka log push policies push calling logs of open APIs to Kafka for analysis.
![](https://support.huaweicloud.com/intl/en-us/ae-ad-1-usermanual-apig/public_sys-resources/note_3.0-en-us.png)
If your gateway does not support this policy, contact technical support to upgrade the gateway to the latest version.
Usage Guidelines
- A maximum of five Kafka log push policies can be created for a gateway.
- APIs bound with a Kafka log push policy will deteriorate in performance by 30%.
Configuration Parameters
Parameter |
Description |
Policy Information |
Broker Address |
Connection address of the target Kafka. Separate multiple addresses with commas (,). |
Topic |
Topic of the target Kafka to report logs to. |
Key |
Partition of Kafka for storing logs as an ordered message queue. If this parameter is left blank, logs are stored in different partitions. |
Retry |
Configuration for retrying when logs fail to be pushed to Kafka.
SASL Configuration |
Security Protocol |
Protocol used for connecting to the target Kafka.
Message Tx/Rx Mechanism |
Message transmission and receiving mechanism of the target Kafka. The default value is PLAIN. |
SASL Username |
This parameter is available only if Security Protocol is set to SASL_PLAINTEXT or SASL_SSL. Username used for SASL or SSL authentication. |
SASL Password |
This parameter is available only if Security Protocol is set to SASL_PLAINTEXT or SASL_SSL. User password used for SASL or SSL authentication. |
Confirm SASL Password |
This parameter is available only if Security Protocol is set to SASL_PLAINTEXT or SASL_SSL. Enter the SASL password again. |
Certificate Content |
This parameter is available only if Security Protocol is set to SASL_SSL. CA certificate used for SSL authentication. |
Metadata Configuration |
System Metadata |
System fields that need to be included in pushed logs. By default, the start_time, request_id, client_ip, request_time, http_status, scheme, request_method, host, uri, upstream_addr, upstream_status, upstream_response_time, http_x_forwarded_for, http_user_agent, and error_type fields are carried in logs. You can also specify other system fields that need to be included. |
Request Data |
API request information that needs to be included in pushed logs.
Response Data |
API response information that needs to be included in pushed logs.
Customized Authentication |
Custom authentication information that needs to be included in pushed logs.
