Help Center/ API Gateway/ User Guide (Kuala Lumpur Region)/ FAQs/ API Publishing/ Can I Specify an Environment for API Debugging?
Updated on 2024-08-07 GMT+08:00
No.
APIG debugs APIs in a specific debugging environment. After debugging is completed, you need to publish your API in an environment, and use code or Postman to add the X-Stage header to specify the environment where you want to call the API.
