Help Center>
API Gateway>
User Guide (ME-Abu Dhabi Region)>
Getting Started>
Calling APIs>
Creating a Credential and Getting Authorized
Updated on 2023-05-09 GMT+08:00
- In the navigation pane, choose API Management > Credentials.
- Click Create Credential and set credential information.
Table 1 Credential information Parameter
Name
Credential name. It is recommended that you enter a name based on naming rules to facilitate search.
Description about the credential.
- Click OK.
Binding to an API
- In the APIs area, click Bind to APIs.
- Select the environment, API group, and API created in Opening APIs, and click OK.
Parent topic: Calling APIs
