Updated on 2024-08-07 GMT+08:00
Bandwidth Monitoring
APIG provides monitoring metrics about inbound and outbound bandwidth.
Inbound and outbound access has been enabled for the target gateway. View the inbound and outbound addresses in the gateway information.
  1. Go to the APIG console.
  2. Select a gateway at the top of the navigation pane.
  3. In the navigation pane, choose Monitoring & Analysis > Bandwidth Monitoring.
  4. Configure the monitoring information according to the following table.
    Table 1 Monitoring information
    IP Address
    Inbound or outbound IP address of a gateway. View the address in the gateway information.
    Time range
    Select 1h, 3h, 12h, 24h, or 7d, or click to specify a custom time range. In the upper right of each monitoring graph dynamically shows the maximum and minimum metric values in the specified time range.
    Auto Refresh
    If this option is enabled, data is automatically refreshed every minute.
    Period
    A cycle when data is aggregated to calculate the maximum, minimum, average, total, or variance value.
