Updated on 2024-08-07 GMT+08:00
Log Analysis
This section describes how to obtain and analyze the API calling logs of a dedicated gateway.
APIs have been called.
  1. Go to the APIG console.
  2. Select a gateway at the top of the navigation pane.
  3. In the navigation pane, choose Monitoring & Analysis > Log Analysis.
  1. Click Configure Log Collection, and change Collect Logs to to enable log collection.
  1. Specify a log group and log stream, and click OK. For details about log groups and log streams, see section "Log Management" in the Log Tank Service User Guide.
  2. Click Log Fields to view the description of each log field. Then view and analyze logs by referring to the log field descriptions.
  3. To export logs, see section "Log Transfer" in the Log Tank Service User Guide.
    Fields in access logs are separated using spaces. The following table describes each log field.
    Table 1 Log field description
    No.
    Field
    remote_addr
    Client IP address.
    2
    request_id
    Request ID.
    3
    api_id
    API ID
    4
    user_id
    Project ID provided by a requester for IAM authentication.
    5
    app_id
    App ID provided by a requester for app authentication.
    6
    time_local
    Time when a request is received.
    7
    request_time
    Request latency.
    8
    request_method
    HTTP request method.
    9
    scheme
    Request protocol.
    10
    host
    Domain name.
    11
    router_uri
    Request URI.
    12
    server_protocol
    Request protocol.
    13
    status
    Response status code.
    14
    bytes_sent
    Response size in bytes, including the status line, header, and body.
    15
    request_length
    Request length in bytes, including the start line, header, and body.
    16
    http_user_agent
    User agent ID.
    17
    http_x_forwarded_for
    X-Forwarded-For header field.
    18
    upstream_addr
    Backend address.
    19
    upstream_uri
    Backend URI.
    20
    upstream_status
    Backend response code.
    21
    upstream_connect_time
    Time taken to establish a connection with the backend.
    22
    upstream_header_time
    Duration from the start of a connection to the first byte received from the backend.
    23
    upstream_response_time
    Duration from the start of a connection to the last byte received from the backend.
    24
    region_id
    Region ID.
    25
    all_upstream_response_time
    Duration from the start of a connection to the last byte received from the backend, in seconds. When a retry occurs, the value is the total time taken.
    26
    errorType
    API request error type. Options:
    • 0: non-throttling error
    • 1: throttling error
    27
    auth_type
    API authentication mode.
    28
    access_model1
    Authentication mode 1.
    29
    access_model2
    Authentication mode 2. Enabling two-factor authentication will use the custom authorizer ID.
    30
    inner_time
    APIG internal processing duration, in seconds.
    31
    proxy_protocol_vni
    VPC endpoint virtual network ID.
    32
    proxy_protocol_vpce_id
    VPC endpoint ID.
    33
    proxy_protocol_addr
    Client IP address.
    34
    body_bytes_sent
    API request body size, in bytes.
    35
    api_name
    API name.
    36
    app_name
    Name of the app used by a requester for authentication.
    37
    provider_app_id
    App ID of an API.
    38
    provider_app_name
    App name of an API.
    39
    custom_data_log1
    Custom log field 1.
    40
    custom_data_log2
    Custom log field 2.
    41
    custom_data_log3
    Custom log field 3.
    42
    custom_data_log4
    Custom log field 4.
    43
    custom_data_log5
    Custom log field 5.
    44
    custom_data_log6
    Custom log field 6.
    45
    custom_data_log7
    Custom log field 7.
    46
    custom_data_log8
    Custom log field 8.
    47
    custom_data_log9
    Custom log field 9.
    48
    custom_data_log10
    Custom log field 10.
    49
    response_source
    Response source. Options:
    • local: APIG
    • remote: backend service
    50
    gzip_ratio
    Ratio of the original response body size to the compressed response body size.
    51
    upstream_scheme
    Backend protocol type.
    52
    group_id
    Group ID.
    53
    apig_err_code
    Gateway error code.
    54
    function_urn
    Function URN.
