Creating an API Group
An API group contains APIs used for the same service. You can manage APIs by group, and must create a group before creating an API.
You can create an API group using the following methods:
- Creating an API Group Directly
You can create APIs for the group as required.
- Importing an API Design File
Import an API file to create a group.
![](https://support.huaweicloud.com/intl/en-us/ae-ad-1-usermanual-apig/public_sys-resources/note_3.0-en-us.png)
- To make your APIs available for users to access, bind independent domain names to the group to which the APIs belong.
- Each API can belong to only one group.
- The system automatically allocates a subdomain name to each API group for internal testing. The subdomain name can be accessed 1000 times a day.
- API group DEFAULT is automatically generated for each gateway. APIs in this group can be called using the IP address of the Virtual Private Cloud (VPC) where the gateway is deployed.
You have created a gateway.
- Log in to the APIG console.
- Select a gateway at the top of the navigation pane.
- Choose API Management > API Groups.
- Choose Create API group > Create Directly, and enter group information.
Table 1 Group information Parameter
Name
API group name.
Description of the API group.
- Click OK.
- Choose Create API Group > Import API Design File.
- Select an API file and click Open.
- Set the import parameters.
Table 2 Parameters for importing APIs Parameter
Import
Options:
- New group: Import APIs to a new API group. If you select this option, the system automatically creates an API group and imports the APIs into this group.
- Existing group: Import APIs to an existing API group. If you select this option, the system adds the APIs to the selected API group while retaining the existing APIs in the API group.
API group
Select an API group if you set Import to Existing group.
Basic Definition Overwrite
Determine whether to overwrite an existing API if the name of the API is the same as that of an imported API.
This parameter is available only if you set Import to Existing group.
Extended Definition Overwrite
If this option is selected, the extended definition items (access control and request throttling policies) of an imported API will overwrite the existing policies with the same name.
- (Optional) To configure the APIs, click Configure Global Settings.
- Click Import Now, and determine whether to publish the APIs.
- Now: Publish the APIs in a specified environment now.
- Later: Publish the APIs later.
- Click OK. The APIs tab is displayed, showing the imported APIs.
Follow-Up Operations
After an API group is created, bind independent domain names to it so that API callers can use them to call open APIs in the group.
