Help Center>
API Gateway>
User Guide>
Shared Gateway (for Existing Users)>
Request Throttling>
Deleting a Request Throttling Policy
Updated on 2024-04-03 GMT+08:00
You can delete request throttling policies you no longer require.
You have created a request throttling policy.
- Access the shared gateway console.
- In the navigation pane, choose API Publishing > Request Throttling.
- Delete a request throttling policy. You can use one of the following methods:
- In the Operation column of the request throttling policy you want to delete, click Delete.
- Click the name of the target request throttling policy, and click Delete in the upper right corner of the displayed request throttling policy details page.
- If a request throttling policy has been bound to an API, unbind the policy and then delete it. To unbind a request throttling policy, go to the policy details page, click Unbind in the row that contains the API from which you want to unbind the policy, and click Yes.
- To delete multiple request throttling policies, select the policies, and click Delete. You can delete a maximum of 1000 request throttling policies at a time.
- Click Yes.
Parent topic: Request Throttling
