Help Center>
API Gateway>
User Guide>
Shared Gateway (for Existing Users)>
Signature Key Management>
Deleting a Signature Key
Updated on 2024-04-03 GMT+08:00
You can delete signature keys you no longer require.
You have created a signature key.
- Access the shared gateway console.
- In the navigation pane, choose API Publishing > Signature Keys.
- Delete a signature key. You can use one of the following methods:
- In the Operation column of the signature key you want to delete, click Delete.
- Click the name of the target signature key, and click Delete in the upper right corner of the displayed signature key details page.
If the signature key has been bound to any APIs, unbind it and then delete it.
- Click Yes.
Parent topic: Signature Key Management
