Monitoring Metrics
Introduction
This section describes the metrics that APIG reports to the Cloud Eye service. You can view metrics and alarms by using the Cloud Eye console.
Namespace
SYS.APIC
Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Monitored Object and Dimension |
Monitoring Period (Minute) |
requests |
Requests |
Number of times that all APIs in a dedicated gateway have been called. |
≥ 0 |
Monitored object: dedicated API gateway Dimension: instance_id |
1 |
error_4xx |
4xx Errors |
Number of times that all APIs in the dedicated gateway return a 4xx error. |
≥ 0 |
1 |
error_5xx |
5xx Errors |
Number of times that all APIs in the dedicated gateway return a 5xx error. |
≥ 0 |
1 |
throttled_calls |
Throttled API Calls |
Number of times that all APIs in the dedicated gateway have been throttled. |
≥ 0 |
1 |
avg_latency |
Average Latency |
Average latency of all APIs in the gateway. |
≥ 0 Unit: ms |
1 |
max_latency |
Maximum Latency |
Maximum latency of all APIs in the gateway. |
≥ 0 Unit: ms |
1 |
req_count |
Requests |
Number of times that an API has been called. |
≥ 0 |
Monitored object: API Dimension: api_id |
1 |
req_count_2xx |
2xx Responses |
Number of times that the API returns a 2xx response. |
≥ 0 |
1 |
req_count_4xx |
4xx Errors |
Number of times that the API returns a 4xx error. |
≥ 0 |
1 |
req_count_5xx |
5xx Errors |
Number of times that the API returns a 5xx error. |
≥ 0 |
1 |
req_count_error |
Total Errors |
Total number of errors returned by the API. |
≥ 0 |
1 |
avg_latency |
Average Latency |
Average latency of the API. |
≥ 0 Unit: ms |
1 |
max_latency |
Maximum Latency |
Maximum latency of the API. |
≥ 0 Unit: ms |
1 |
input_throughput |
Incoming Traffic |
Incoming traffic of the API. |
≥ 0 Unit: Byte, KB, MB, or GB |
1 |
output_throughput |
Outgoing Traffic |
Outgoing traffic of the API. |
1 |
node_system_load |
Node System Load |
Load details of a gateway node on the data plane. 1 means low water level, 2 means medium water level, and 3 means high water level. |
1, 2, 3 Unit: count |
Monitored object: gateway node Dimension: node_ip |
1 |
node_cpu_usage |
Node CPU Usage |
CPU usage details of a gateway node on the data plane. |
≥ 0 Unit: % |
1 |
node_memory_usage |
Node Memory Usage |
Memory usage details of a gateway node on the data plane. |
≥ 0 Unit: % |
1 |
Dimension
Key |
Value |
instance_id |
Dedicated gateway |
instance_id,node_ip |
Dedicated gateway node |
instance_id,api_id |
API |
