Help Center/ API Gateway/ User Guide/ Managing APIs/ Importing and Exporting APIs/ Importing APIs through an API Design File
Updated on 2025-09-26 GMT+08:00
You can import Swagger and OpenAPI APIs to a new or existing API group on APIG. Before importing APIs, complete the extended definition of APIG.
Precautions
  • The API group and API quotas in API Gateway are sufficient.
  • If you use the title property in Swagger inf and OpenAPI info to specify an API group name, the name of a new API group cannot be the same as that of an existing one.
  • If a conflict exists when you import APIs, the former API is imported successfully and the latter API cannot be imported. For example, if two APIs with the same name or request path exist in the imported API definition, a success message is displayed for the first imported API, and a failure message is displayed for the API to be imported subsequently.
  • If the definition of an API you are importing is the same as that of an existing API, you can overwrite the existing API or retain it. If you leave the existing API alone, the new API will not be imported.
  • If Extended Definition Overwrite is selected, the extended definition items (access control and request throttling policies) of an imported API will overwrite the existing extended definition items with the same name.
  • Imported APIs will not be automatically published in an environment. You can choose to publish them immediately or later.
  • The load balance channel, SSL certificate, and credential of an API cannot be imported.
Importing an API Design File
  1. Go to the APIG console.
  2. Select a dedicated gateway at the top of the navigation pane.
  1. APIs can be imported in the following path:
    • In the navigation pane, choose API Management > API Groups. Choose Create API Group > Import API Design File.
    • Choose API Management > APIs. Click Import APIs.
  2. Select an API file and click Open.
  3. Set the parameters according to the following table.
    Table 1 Parameters for importing APIs
    Import
    Options:
    • New group: Import APIs to a new API group. If you select this option, the system automatically creates an API group and imports the APIs into this group.
    • Existing group: Import APIs to an existing API group. If you select this option, the system adds the APIs to the selected API group while retaining the existing APIs in the API group.
    API group
    Select an API group if you set Import to Existing group.
    Basic Definition Overwrite
    Determine whether to overwrite an existing API if the name of the API is the same as that of an imported API.
    This parameter is available only if you set Import to Existing group.
    If this option is selected, the extended definition items (access control and request throttling policies) of an imported API will overwrite the existing policies with the same name.
  4. (Optional) To configure the APIs, click Configure Global Settings.
    1. Change the authentication mode. For details, see 5.b.
    2. Modify the backend request configuration. For details, see 1.
    3. Click Next. You can view the configuration details in form, JSON, or YAML format.
    4. Confirm the configuration and click Submit.
  5. In the displayed dialog box, determine whether to publish the APIs now.
    • Now: Publish the APIs in a specified environment now.
    • Later: Publish the APIs later.
  6. Click OK. The APIs tab is displayed, showing the imported APIs.
Importing an HTTP Backend Service API
Import the request parameter definition of an HTTP backend service API that uses the GET method and is accessed through IAM authentication.
Swagger example:
swagger: "2.0"
info:
  title: "importHttpEndpoint10"
  description: "import apis"
  version: "1.0"
host: "api.account.com"
paths:
  '/http/{userId}':
    get:
      operationId: "getUser3"
      description: "get user by userId"
      security:
      - apig-auth-iam: []
      schemes:
      - https
      parameters:
      - name: "test"
        description: "authorization token"
        type: "string"
        in: "header"
        required: true
      - name: "userId"
        description: "user id"
        type: "string"
        in: "path"
        required: true
      responses:
        "200":
          description: "user information"
      x-apigateway-request-type: "public"
      x-apigateway-cors: true
      x-apigateway-is-send-fg-body-base64: true
      x-apigateway-match-mode: "NORMAL"
      x-apigateway-backend:
        type: "HTTP"
        parameters:
        - name: "userId"
          value: "userId"
          in: "query"
          origin: "REQUEST"
        - name: "X-Invoke-User"
          value: "apigateway"
          in: "header"
          origin: "CONSTANT"
          description: "invoke user"
        httpEndpoints:
          address: "example.com"
          scheme: "http"
          method: "GET"
          path: "/users"
          timeout: 30000
securityDefinitions:
  apig-auth-app:
    in: header
    type: apiKey
    x-apigateway-auth-type: AppSigv1
  apig-auth-iam:
    in: header
    type: apiKey
    x-apigateway-auth-type: IAM
OpenAPI example:
openapi: 3.0.0
info:
  title: importHttpEndpoint10
  version: '1.0'
servers:
  - url: >-
      http://abc.com
  - url: >-
      https://abc.com
paths:
  '/http/{userId}':
    get:
      description: get user by userId
      operationId: getUser3
      parameters:
        - description: authorization token
          example: ''
          in: header
          required: true
          schema:
            maxLength: 0
            maximum: 0
            minimum: 0
            type: string
          x-apigateway-pass-through: always
        - description: user id
          example: ''
          in: path
          required: true
          schema:
            maxLength: 0
            maximum: 0
            minimum: 0
            type: string
      responses:
        default-cors:
          description: response example
          x-apigateway-result-failure-sample: ''
          x-apigateway-result-normal-sample: ''
      security:
        - apig-auth-iam: []
      servers:
        - url: >-
            https://abc.com
        httpEndpoints:
          address: example.com
          description: ''
          enableClientSsl: false
          method: GET
          path: /users
          retryCount: '-1'
          scheme: http
          timeout: 30000
        parameters:
          - description: invoke user
            in: HEADER
            origin: CONSTANT
            value: apigateway
            in: QUERY
            origin: REQUEST
            value: userId
        type: HTTP
      x-apigateway-match-mode: NORMAL
      x-apigateway-request-type: public
      x-apigateway-response: default
components:
  responses:
    default-cors:
      headers:
        Access-Control-Allow-Origin:
          schema:
            default: '*'
            type: string
  securitySchemes:
    apig-auth-app:
      in: header
      type: apiKey
    apig-auth-app-header:
      in: header
      type: apiKey
      x-apigateway-auth-opt:
        appcode-auth-type: header
    apig-auth-iam:
      in: header
      type: apiKey
  x-apigateway-responses:
    default: {}
Importing an HTTP VPC Backend Service API
Import the request parameter definition of an HTTP VPC backend service API that uses the ANY method and is accessed through app authentication.
Swagger example:
swagger: "2.0"
info:
  title: "importHttpVpcEndpoint"
  version: "1.0"
paths:
  '/http-vpc':
    x-apigateway-any-method:
      operationId: "userOperation"
      description: "user operation resource"
      security:
      - apig-auth-app: []
      schemes:
      - https
      parameters:
      - name: "Authorization"
        description: "authorization signature"
        type: "string"
        in: "header"
        required: true
      responses:
        "default":
          description: "endpoint response"
      x-apigateway-match-mode: "SWA"
        type: "HTTP-VPC"
        parameters:
          value: "apigateway"
          in: "header"
          origin: "CONSTANT"
        httpVpcEndpoints:
          scheme: "http"
          method: "GET"
          path: "/users"
          timeout: 30000
  apig-auth-app:
    in: header
    type: apiKey
  apig-auth-iam:
    in: header
    type: apiKey
OpenAPI example:
openapi: 3.0.0
info:
  description: import apis
  title: importHttpVpcEndpoint
  version: '1.0'
servers:
  - url: >-
      http://abc.com
  - url: >-
      https://abc.com
paths:
  /http-vpc:
      description: user operation resource
      operationId: userOperation
      parameters:
        - description: authorization signature
          example: ''
          in: header
          required: true
          schema:
            maxLength: 0
            maximum: 0
            minimum: 0
            type: string
      responses:
        default-cors:
      security:
        - apig-auth-app: []
      servers:
        - url: >-
            https://abc.com
        httpVpcEndpoints:
          cascade_flag: false
          description: ''
          method: GET
          path: /users
          retryCount: '-1'
          scheme: http
          timeout: 30000
        parameters:
            in: HEADER
            origin: CONSTANT
            value: apigateway
        type: HTTP-VPC
      x-apigateway-match-mode: SWA
components:
  responses:
    default-cors:
      headers:
          schema:
            default: '*'
            type: string
  securitySchemes:
    apig-auth-app:
      in: header
      type: apiKey
      in: header
      type: apiKey
    apig-auth-iam:
      in: header
      type: apiKey
  x-apigateway-responses: {}
Importing a Function Backend Service API
Import the request parameter definition of a FunctionGraph backend service API that uses the GET method and is accessed through IAM authentication.
Swagger example:
swagger: "2.0"
info:
  title: "importFunctionEndpoint"
  version: "1.0"
paths:
  '/function/{name}':
    get:
      operationId: "invokeFunction"
      description: "invoke function by name"
      security:
      - apig-auth-iam: []
      schemes:
      - https
      parameters:
      - name: "test"
        type: "string"
        in: "header"
        required: true
      - name: "name"
        description: "function name"
        type: "string"
        in: "path"
        required: true
      responses:
        "200":
          description: "function result"
        type: "FUNCTION"
        parameters:
        - name: "functionName"
          value: "name"
          in: "query"
          origin: "REQUEST"
          value: "apigateway"
          in: "header"
          origin: "CONSTANT"
        functionEndpoints:
          function-urn: "your function urn address"
          version: "your function version"
          invocation-type: "async"
          timeout: 30000
  apig-auth-app:
    in: header
    type: apiKey
  apig-auth-iam:
    in: header
    type: apiKey
OpenAPI example:
openapi: 3.0.0
info:
  version: '1.0'
servers:
  - url: >-
      http://api.account.com
  - url: >-
      https://api.account.com
paths:
  /function/{name}:
    get:
      description: invoke function by name
      operationId: invokeFunction
      parameters:
        - description: function name
          in: path
          required: true
          schema:
            maxLength: 0
            maximum: 0
            minimum: 0
            type: string
          example: ''
          in: header
          required: true
          schema:
            maxLength: 0
            maximum: 0
            minimum: 0
            type: string
          example: ''
      responses:
        default-cors:
      security:
        - apig-auth-iam: []
      servers:
        - url: >-
        functionEndpoints:
          alias-urn: ''
          description: ''
          invocation-type: async
          network-type: V1
          timeout: 30000
        parameters:
            in: HEADER
            origin: CONSTANT
            value: apigateway
            in: QUERY
            origin: REQUEST
            value: name
        type: FUNCTION
components:
  responses:
    default-cors:
      headers:
          schema:
            default: '*'
            type: string
  securitySchemes:
    apig-auth-app:
      in: header
      type: apiKey
    apig-auth-iam:
      in: header
      type: apiKey
    default: {}
Importing a Mock Backend Service API
Import the definition of a Mock backend service API that uses the GET method and is accessed without authentication.
Swagger example:
swagger: "2.0"
info:
  title: "importMockEndpoint"
  version: "1.0"
paths:
  '/mock':
    get:
      operationId: "mock"
      description: "mock test"
      schemes:
      - http
      responses:
        "200":
          description: "mock result"
      x-apigateway-request-type: "private"
        type: "MOCK"
        mockEndpoints:
          result-content: "{\"message\": \"mocked\"}"
  apig-auth-app:
    in: header
    type: apiKey
  apig-auth-iam:
    in: header
    type: apiKey
OpenAPI example:
openapi: 3.0.0
info:
  version: '1.0'
servers:
  - url: >-
      http://abc.com
  - url: >-
      https://abc.com
paths:
  /mock:
    get:
      description: mock test
      operationId: mock
      responses:
        default-cors:
      servers:
        - url: >-
            http://abc.com
        mockEndpoints:
          description: ''
          result-content: '{"message": "mocked"}'
        type: MOCK
      x-apigateway-request-type: private
components:
  responses:
    default-cors:
      headers:
          schema:
            default: '*'
            type: string
  securitySchemes:
    apig-auth-app:
      in: header
      type: apiKey
      in: header
      type: apiKey
    apig-auth-iam:
      in: header
      type: apiKey
    default: {}
Follow-Up Operations
Publish the imported APIs in an environment so that they can be called by users.
