x-apigateway-backend.httpVpcEndpoints
Meaning: HTTP VPC backend service definition.
Scope of effect: x-apigateway-backend
Example:
paths: '/users/{userId}': get: produces: - "application/json" parameters: - name: "X-Auth-Token" description: "Authentication token" type: "string" in: "header" required: true responses: default: description: "default response" x-apigateway-request-type: "public" x-apigateway-backend: type: "HTTP-VPC" httpVpcEndpoints: name: "vpc-test-1" scheme: "http" method: "GET" path: "/users" timeout: 30000
Parameter |
Mandatory |
Type |
Description |
name |
Yes |
Array |
VPC channel name. |
scheme |
Yes |
String |
Backend request protocol. HTTP and HTTPS are supported. |
method |
Yes |
String |
Backend request method. The options include GET, POST, PUT, DELETE, HEAD, OPTIONS, PATCH, and ANY. |
path |
Yes |
String |
Backend request path, which can contain variables. |
timeout |
No |
Number |
Backend request timeout in milliseconds. The value ranges from 1 to 60,000, and the default value is 5000. |
