Updated on 2025-09-26 GMT+08:00
x-apigateway-backend
Meaning: API backend definition.
Scope of effect: Operation Object (2.0)/Operation Object (3.0)
Example:
paths:
  '/users/{userId}':
    get:
      produces:
        - "application/json"
      responses:
        default:
          description: "default response"
      x-apigateway-request-type: "public"
      x-apigateway-backend:
        type: "backend endpoint type"
Table 1 Parameter description
Mandatory
Type
Yes
String
Backend service definition.
type
Yes
String
Backend service type. The options include HTTP, HTTP-VPC, FUNCTION, and MOCK.
parameters
No
x-apigateway-backend.parameters
Backend parameters.
httpEndpoints
No
x-apigateway-backend.httpEndpoints
HTTP backend service definition.
httpVpcEndpoints
No
x-apigateway-backend.httpVpcEndpoints
HTTP VPC backend service definition.
functionEndpoints
No
x-apigateway-backend.functionEndpoints
Function backend service definition.
mockEndpoints
No
x-apigateway-backend.mockEndpoints
Mock backend service definition.
httpVpcMemberGroupEndpoints
No
x-apigateway-backend.httpVpcMemberGroupEndpoints
HTTP VPC member group backend service definition.
It is restricted. To use it, submit a service ticket.
