Help Center>
API Gateway>
User Guide>
API Management>
Importing and Exorting APIs>
Extended Definition>
x-apigateway-any-method
Updated on 2024-04-19 GMT+08:00
Meaning: API request method used by default if no HTTP request method is specified.
Scope of effect: Path Item Object (2.0)/Path Item Object (3.0)
Example:
paths: '/path': get: produces: - application/json responses: "200": description: "get response" x-apigateway-any-method: produces: - application/json responses: "200": description: "any response"
Parameter |
Mandatory |
Type |
Description |
x-apigateway-any-method |
No |
String |
Request method. |
Parent topic: Extended Definition
