x-apigateway-backend.parameters
Meaning: API backend service definition.
Scope of effect: x-apigateway-backend
Example:
paths:
'/users/{userId}':
get:
produces:
- "application/json"
parameters:
- name: "X-Auth-Token"
description: "Authentication token"
type: "string"
in: "header"
required: true
- name: "userId"
description: "Username"
type: "string"
in: "path"
required: true
responses:
default:
description: "default response"
x-apigateway-request-type: "public"
x-apigateway-backend:
type: "HTTP"
parameters:
- name: "userId"
value: "userId"
in: "query"
origin: "REQUEST"
- name: "X-Invoke-User"
value: "apigateway"
in: "header"
origin: "CONSTANT"
description: "Caller"
Parameter |
Mandatory |
Type |
Description |
name |
Yes |
String |
Parameter name. It contains a maximum of 32 bytes, including letters, digits, underscores (_), hyphens (-), and periods (.) and must start with a letter. The names of header parameters are not case-sensitive. |
value |
Yes |
String |
Parameter value, which is a parameter name if the parameter comes from a request. |
in |
Yes |
String |
Parameter location, which can be header, query, or path. |
origin |
Yes |
String |
Parameter mapping source. The options include REQUEST and CONSTANT. |
description |
No |
String |
Parameter meaning. |
