Help Center>
API Gateway>
User Guide>
API Management>
Importing and Exorting APIs>
Extended Definition>
x-apigateway-backend.mockEndpoints
Updated on 2023-12-08 GMT+08:00
Meaning: Mock backend service definition.
Scope of effect: x-apigateway-backend
Example:
paths: '/users/{userId}': get: produces: - "application/json" parameters: - name: "X-Auth-Token" description: "Authentication token" type: "string" in: "header" required: true responses: default: description: "default response" x-apigateway-request-type: "public" x-apigateway-backend: type: "MOCK" mockEndpoints: result-content: "mocked"
Parameter |
Mandatory |
Type |
Description |
result-content |
Yes |
String |
Mock response. |
Parent topic: Extended Definition
