Updated on 2025-12-09 GMT+08:00
Viewing API Call Logs
APIG provides visualized analysis and statistics of APIs, allowing you to view API calling logs.
APIs have been called.
  1. Go to the APIG console.
  2. Select a gateway at the top of the navigation pane.
  3. In the navigation pane, choose Monitoring & Analysis > Log Analysis.
  4. Enable log analysis.
    1. On the Log Analysis page, click Configure Log Collection.
      If the gateway is in the CN South-Guangzhou region, click Configure Logs and Tracing.
    2. In the displayed dialog box, configure log information and click OK.
    Table 1 Configuring log information
    Collect Logs
    Indicates whether to enable log collection. By default, it is disabled. You can view API call logs only after the parameter is enabled.
    Log Group
    Select the log group to which the log stream belongs.
    If no log group is available, click View Log Groups to go to the LTS console and create a log group. For details, see Creating a Log Group.
    Log Stream
    Select the log stream for storing the API call logs.
    If no log stream is available, click View Log Streams to go to the LTS console and create a log stream. For details, see Creating a Log Stream.
    APM Applications
    Select one or more APM applications to view the complete tracing and service topology on APM. Currently, this parameter is available only in the CN South-Guangzhou region.
    If no APM application is available, click Create APM Application to create one. For details, see Creating an Application.
  1. After the log analysis function is enabled, view the call logs of all open APIs in real time on the console. For details about the log fields, see Table 2.
  2. To export logs, see Log Transfer.
    Fields in access logs are separated using spaces. The following table describes each log field.
    Table 2 Log field description
    No.
    Field
    remote_addr
    Client IP address.
    2
    request_id
    Request ID.
    3
    api_id
    API ID.
    4
    user_id
    Project ID provided by a requester for IAM authentication.
    5
    app_id
    Application ID provided by a requester using app authentication.
    6
    time_local
    Request completion time.
    7
    request_time
    Request latency (unit: second).
    8
    request_method
    HTTP request method.
    9
    scheme
    Request protocol.
    10
    host
    Domain name.
    11
    router_uri
    Request URI.
    12
    server_protocol
    Request protocol.
    13
    status
    Response status code.
    14
    bytes_sent
    Response size in bytes, including the status line, header, and body.
    15
    request_length
    Request length in bytes, including the start line, header, and body.
    16
    http_user_agent
    User agent ID.
    17
    http_x_forwarded_for
    X-Forwarded-For header field.
    18
    upstream_addr
    Backend address.
    19
    upstream_uri
    Backend URI.
    20
    upstream_status
    Backend response code.
    21
    upstream_connect_time
    Time taken for establishing a connection with the backend, in seconds.
    22
    upstream_header_time
    Duration from the beginning of the establishment of a connection to receiving the first byte from the backend, in seconds.
    23
    upstream_response_time
    Duration from the start of a connection to the last byte received from the backend, in seconds.
    24
    region_id
    Region ID.
    25
    all_upstream_response_time
    Duration from the start of a connection to the last byte received from the backend, in seconds. When a retry occurs, the value is the total time taken.
    26
    errorType
    API request error type. Options:
    • 0: non-throttling error
    • 1: throttling error
    27
    auth_type
    API authentication mode.
    28
    access_model1
    Authentication mode 1.
    29
    access_model2
    Authentication mode 2. Enabling two-factor authentication will use the custom authorizer ID.
    30
    inner_time
    APIG internal processing duration, in seconds.
    31
    proxy_protocol_vni
    VPC endpoint virtual network ID.
    32
    proxy_protocol_vpce_id
    VPC endpoint ID.
    33
    proxy_protocol_addr
    Client IP address.
    34
    body_bytes_sent
    API request body size, in bytes.
    35
    api_name
    API name.
    36
    app_name
    Name of the app used by a requester for authentication.
    37
    provider_app_id
    App ID of an API.
    38
    provider_app_name
    App name of an API.
    39
    custom_data_log1
    Custom log field 1.
    40
    custom_data_log2
    Custom log field 2.
    41
    custom_data_log3
    Custom log field 3.
    42
    custom_data_log4
    Custom log field 4.
    43
    custom_data_log5
    Custom log field 5.
    44
    custom_data_log6
    Custom log field 6.
    45
    custom_data_log7
    Custom log field 7.
    46
    custom_data_log8
    Custom log field 8.
    47
    custom_data_log9
    Custom log field 9.
    48
    custom_data_log10
    Custom log field 10.
    49
    response_source
    Response source. Options:
    • local: APIG
    • remote: backend service
    50
    gzip_ratio
    Ratio of the original response body size to the compressed response body size.
    51
    upstream_scheme
    Backend protocol type.
    52
    group_id
    Group ID.
    53
    apig_err_code
    Gateway error code.
    54
    function_urn
    Function URN.
    55
    cache_status
    Indicates whether the request hits the cache.
    • MISS: No response cache is available. This value is usually used when an API is requested for the first time.
    • BYPASS: The request bypasses the cache and is directly forwarded to the upstream server.
    • STALE: The response in the cache has expired and a new response needs to be obtained from the upstream server.
    • HIT: The response is provided from the cache, not obtained from the upstream server in real time.
    56
    authorizer_downgrade
    Indicates the downgrade flag after the Relaxed Mode is enabled for custom authorizer.
    • 1: Only the frontend custom authorizer is downgraded.
    • 2: Only the backend custom authorizer is downgraded.
    • 3: Both frontend and backend custom authorizers are downgraded.
    • -: No downgrade is performed.
    57
    x_apm_version
    Tracing version.
    58
    x_apm_trace_id
    Unique global trace ID of a request.
    59
    x_apm_parent_span_id
    Parent span ID of the request.
    60
    x_apm_trace_flags
    Indicates whether to enable sampling. 01: enabled; 02: disabled.
    61
    x_apm_span_id
    Span ID of the request.
