Updated on 2024-08-07 GMT+08:00
x-apigateway-auth-type
Meaning: Swagger-based apiKey authentication format, which defines an authentication mode provided by APIG.
Scope of effect: Security Scheme Object (2.0)/Security Scheme Object (3.0)
Swagger:
securityDefinitions:
  apig-auth-app:
    in: header
    type: apiKey
    x-apigateway-auth-type: AppSigv1
  apig-auth-iam:
    in: header
    type: apiKey
    x-apigateway-auth-type: IAM
OpenAPI example:
securitySchemes:
    apig-auth-app:
      in: header
      type: apiKey
    apig-auth-iam:
      in: header
      type: apiKey
Table 1 Parameter description
Mandatory
Type
Yes
String
Authentication mode used on APIG. AppSigv1 and IAM are supported.
type
Yes
String
Authentication type. Only apiKey is supported.
name
Yes
String
Name of the parameter for authentication.
in
Yes
String
Only header is supported.
description
No
String
Description about the authentication.
