Help Center/
API Gateway/
User Guide (Kuala Lumpur Region)/
API Management/
Importing and Exorting APIs/
Extended Definition/
x-apigateway-backend.mockEndpoints
Updated on 2024-08-07 GMT+08:00
Meaning: Mock backend service definition.
Scope of effect: x-apigateway-backend
Example:
paths:
'/users/{userId}':
get:
produces:
- "application/json"
parameters:
- name: "X-Auth-Token"
description: "Authentication token"
type: "string"
in: "header"
required: true
responses:
default:
description: "default response"
x-apigateway-request-type: "public"
x-apigateway-backend:
type: "MOCK"
mockEndpoints:
result-content: "mocked"
Parameter |
Mandatory |
Type |
Description |
result-content |
Yes |
String |
Mock response. |
Parent topic: Extended Definition
