Editing Cloud Server Configurations of a VPC Channel
You can add or remove cloud servers and edit cloud server weights for VPC channels to meet service requirements.
You have created a VPC channel.
- Access the shared gateway console.
- In the navigation pane, choose API Publishing > VPC Channels.
- Click the name of the target VPC channel.
- Click the Cloud Servers tab.
- Add or remove cloud servers and edit cloud server weights.
- Adding cloud servers
- Click Select Cloud Server.
- Select the cloud servers you want to add, set cloud server weights, and click OK.
To ensure a successful health check and service availability, configure the security groups of the backend cloud servers to allow access from 100.125.0.0/16.
- Removing cloud servers
- In the Operation column of the cloud servers you want to remove, click Remove.
- Click Yes.
- Editing the weight of a cloud server
- In the Weight column of the target cloud server, click
. - Change the weight and click
- Editing the weights of multiple cloud servers
- Select the cloud servers to be edited, and click Edit Weight.
- Change the weights of the selected cloud servers, and click OK.
