Help Center>
API Gateway>
User Guide>
Shared Gateway (for Existing Users)>
Monitoring>
Creating Alarm Rules
Updated on 2024-04-03 GMT+08:00
You can create alarm rules to monitor the status of your APIs.
An alarm rule consists of a rule name, monitored objects, metrics, alarm thresholds, monitoring interval, and notification.
An API has been called.
- Access the shared gateway console.
- In the navigation pane, choose API Publishing > APIs.
- Click the name of the target API.
- On the Dashboard tab page, click View Metric to access the Cloud Eye console. Then create an alarm rule. For details, see Creating an Alarm Rule.
Parent topic: Monitoring
