Notes and Constraints
Quota Limits
To change the default restrictions, increase the quota by referring to
- It takes 5 to 10 seconds for a new or modified APIG resource to take effect.
- The maximum quota may be slightly exceeded in case of high concurrency, but resource usage will not be affected.
Item |
Default Restriction |
Modifiable |
Gateways |
5 |
API groups |
1500 |
APIs |
Number of APIs for each gateway edition:
APIs |
1000 for each group |
x |
Backend policies |
5 |
Apps (credentials) |
50. The app quota includes the apps you have created. |
Request throttling policies |
Environments |
10 |
Signature keys |
200 |
Access control policies |
100 |
VPC channels (load balance channels) |
200 |
Variables |
You can create a maximum of 50 variables for an API group in each environment. |
Independent domain names |
A maximum of five independent domain names can be bound to an API group. |
ECSs |
A maximum of 10 ECSs can be added to a VPC channel. |
Parameters |
A maximum of 50 parameters can be created for an API. |
API publication records |
A maximum of 10 publication records of an API can be retained for each environment. |
API access rate |
Up to 6000 times per second |
Excluded applications (Credentials) |
A maximum of 30 excluded apps can be added to a request throttling policy. |
Excluded tenants |
A maximum of 30 excluded tenants can be added to a request throttling policy. |
Access to a subdomain name (debugging domain name) |
A subdomain name can be accessed up to 1000 times a day. |
x |
Maximum size of an API request package |
12 MB |
TLS protocol |
TLS 1.1 and TLS 1.2 are supported. TLS 1.2 is recommended. |
Custom authorizers |
50 |
x |
Plug-ins |
500 |
HTTP protocol |
When the HTTP protocol is used, the maximum size of URL+Header is 32 KB. |
x |
