x-apigateway-backend.httpEndpoints
Meaning: HTTP backend service definition.
Scope of effect: x-apigateway-backend
Example:
paths:
  '/users/{userId}':
    get:
      produces:
        - "application/json"
      parameters:
        - name: "X-Auth-Token"
          description: "Authentication token"
          type: "string"
          in: "header"
          required: true
      responses:
        default:
          description: "default response"
      x-apigateway-request-type: "public"
      x-apigateway-backend:
        type: "HTTP"
        httpEndpoints:
          address: "example.com"
          scheme: "http"
          method: "GET"
          path: "/users"
          timeout: 30000
Table 1 Parameter description
Mandatory
Type
address
Yes
Array
Backend service address. The format is <Domain name or IP address>:[Port number]
scheme
Yes
String
Backend request protocol. HTTP and HTTPS are supported.
method
Yes
String
Backend request method. The options include GET, POST, PUT, DELETE, HEAD, OPTIONS, PATCH, and ANY.
path
Yes
String
Backend request path, which can contain variables.
timeout
No
Number
Backend request timeout in milliseconds. The range is 1–60,000, and the default value is 5000.
