Updated on 2023-05-09 GMT+08:00
Response Headers
The following table describes the response headers that APIG adds to the response returned when an API is called.
X-Apig-Mode: debug indicates API debugging information.
Response Header
Remarks
X-Request-Id
Request ID.
Returned for all valid requests.
X-Apig-Latency
Duration from the time when APIG receives a request to the time when the backend returns a message header.
Returned only when the request header contains X-Apig-Mode: debug.
X-Apig-Upstream-Latency
Duration from the time when APIG sends a request to the backend to the time when the backend returns a message header.
Returned only when the request header contains X-Apig-Mode: debug and the backend type is not Mock.
X-Apig-RateLimit-api
API request limit information.
Example: remain:9,limit:10,time:10 second.
Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called.
X-Apig-RateLimit-user
User request limit information.
Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called by a user.
X-Apig-RateLimit-app
Credential request limit information.
Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called by a credential.
X-Apig-RateLimit-ip
IP address request limit information.
Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called by an IP address.
X-Apig-RateLimit-api-allenv
Default API request limit information.
Example: remain:199,limit:200,time:1 second.
