Help Center/ API Gateway/ User Guide (ME-Abu Dhabi Region)/ FAQs/ API Authentication/ Common Errors Related to IAM Authentication Information
Updated on 2023-05-09 GMT+08:00
You may encounter the following errors related to IAM authentication information:
Incorrect IAM authentication information: verify aksk signature fail
  "error_msg": "Incorrect IAM authentication information: verify aksk signature fail, ......
  "error_code": "APIG.0301",
  "request_id": "******"
Possible Cause
The signature algorithm is incorrect, and the signature calculated by the client is different from that calculated by APIG.
Solution
  1. Obtain the canonicalRequest calculated by APIG.
    Obtain request_id from the body of the error message, search for error.log (you can view this file on CLS) of the shubao node based on request_id, and obtain canonicalRequest from error.log.
    2019/01/26 11:34:27 [error] 1211#0: *76 [lua] responses.lua:170: rewrite(): 473a4370fbaf69e42f9da243eb8f8c52;app-1;Incorrect IAM authentication information: verify signature fail;SDK-HMAC-SHA256 Access=071fe245-9cf6-4d75-822d-c29945a1e06a, SignedHeaders=host;x-sdk-date, Signature=b2ef2cddcef89cbfe22974c988909c1a94b1ac54114c30b8fe083d34a259e0f5;canonicalRequest:GET
    /app1/
    host:test.com
    x-sdk-date:20190126T033427Z
    host;x-sdk-date
    e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855, client: 192.168.0.1, server: shubao, request: "GET /app1 HTTP/1.1", host: "test.com"
  2. Obtain the canonicalRequest calculated by the client by printing logs or using debug interrupts. The following table describes the functions used to calculate the canonicalRequest in the SDKs of different languages.
    Table 1 Functions for calculating canonicalRequest in the SDKs of common languages
    Language
    Function
    Java
    Sign function in com.cloud.sdk.auth.signer.DefaultSigner.class of libs/java-sdk-core-*.jar
    C
    sig_sign function in signer.c
    C++
    Signer::createSignature function in signer.cpp.
    C#
    Sign function in signer.cs
    Go
    Sign function in signer.go
    JavaScript
    Signer.prototype.Sign function in signer.js
    Python
    Sign function in signer.py
    PHP
    Sign function in signer.php
    Example: cannonicalRequest obtained at a debug interrupt
    POST
    /app1/
    host:test.com
    x-sdk-date:20190126T033950Z
    host;x-sdk-date
  3. Check whether the cannonicalRequest in 1 is the same as that in 2.
    • Yes: Check whether the AK and SK are correct, for example, without spaces.
    • No:
      • Different in line 1: The request method must be the same.
      • Different in line 2: The request path must be the same.
      • Different in line 3: The request parameters must be the same.
      • Different in lines 4 to 5: The request header must be the same in each line.
      • Different in line 7: The number of request header parameters must be the same as the number of request header lines.
      • Different in line 8: The request body must be the same.
    Table 2 canonicalRequest of APIG and a client
    Line No.
    APIG
    Client
    Request method
    GET
    POST
    2
    Request path
    /app1/
    /app1/
    3
    Request parameters
    None
    None
    4
    Request header
    host:test.com
    host:test.com
    5
    Request header
    6
    Blank line
    7
    Request header parameters
    host;x-sdk-date
    host;x-sdk-date
    8
    Request body hash value
Incorrect IAM authentication information: AK access failed to reach the limit,forbidden
  "error_msg": "Incorrect IAM authentication information: AK access failed to reach the limit,forbidden." ......
Possible Causes
  • The AK/SK signature calculation is incorrect. Resolve the problem by referring to Incorrect IAM authentication information: verify aksk signature fail.
  • The AK and SK do not match.
  • AK/SK authentication fails for more than five consecutive times, and the AK/SK pair is locked for five minutes. (Authentication requests are rejected within this period).
  • An expired token is used for token authentication.
Incorrect IAM authentication information: decrypt token fail
  "error_msg": "Incorrect IAM authentication information: decrypt token fail",
Possible Cause
The token cannot be parsed for IAM authentication of the API.
Solution
  • Check whether the token is correct.
  • Check whether the token has been obtained in the environment where the API is called.
Incorrect IAM authentication information: Get secretKey failed
"error_msg": "Incorrect IAM authentication information: Get secretKey failed,ak:******,err:ak not exist",
Possible Cause
The AK used for IAM authentication of the API does not exist.
Solution
Check whether the AK is correct.
